Following my previous question, I'm getting closer to thinking about putting together this mains frequency monitor. I would just like to do a sanity check on my electronics before I order the components and the board. Please keep in mind I am not qualified in this so I have had to research how all this will work.
Circuit layout
A and B inputs will accept power from a 16VAC 1.25A unregulated power pack.
C1 is a 1µF 25V 85°C ceramic capacitor. I guess this is mostly unnecessary as the power pack should filter any DC bias, but it won't hurt.
D1 is an IN4001 1A standard recovery diode.
R1 is a 300ohm 500V 3W resistor. The RMS power is 16VAC, which is half-wave rectified, so that's sqrt(2) * 16 = ~24V peak @ 300ohm = 80mA peak, and about 25mA on average (right?)
IC1 is a 4N28 optocoupler. It's weird, in one data sheet I see 80mA max forward current on inputs but in another I see 60mA. Anyway, the average should be 25mA so I guess that's probably going to be okay?
The Arduino I will use is the Arduino Micro, as it's quite small and also has a 16Mhz crystal oscillator that will provide a more stable clock than a ceramic resonator. The Arduino will be powered by USB, which I believe is 5V. The digital I/O pins I believe will also operate at 5V and are rated at 40mA max.
C will come from one of the Arduino's digital output pins, and D will go to the Arduino's GND.
R2 is a 150ohm 500mW 250V resistor, that should ensure the CD current does not exceed 40mA @ 5V.
Now, assuming the components look okay and the circuit looks okay (I assume the circuit is fine), I just had some questions:
  1. Do I need to add anything to the output of the 4N28 coming from the input? I think with a regular transistor, some of the base current gets added to the collector current?
  2. What can I expect the response on the output of the 4N28 to look like? I assumed that it would more-or-less be a square wave, where even a tiny current on the input would activate the transistor and allow the output current to flow freely on the other side, but someone has suggested that this might not be the case?
  3. The way it is set up, the Digital I/O pin can be "trying" to output or not, and that's basically irrelevant to what the transistor is doing. When the transistor is on, the output current from the pin will successfully flow to GND. I assume there is a way to detect this in the Arduino? Something like setting the output pin to 1 and check in loop when there is or is no current flowing?
Thank you!
Ozzah
  • 193
You should remove the capacitor. It won't remove any DC offset because there can be no DC offset. From where would the DC offset be relative? There is only two points in the circuit, and both of them are direct from the transformer and is an AC waveform. There is no concept of a DC offset in such a circuit. All the capacitor will do is impose a phase change between the current and voltage of the AC waveform limiting the current during the conducting period of the diodes. You have a resistor for that function.
You make some incorrect assumptions about how to read the data. You talk about outputting a signal and somehow finding out if the transistor is on or not by if that signal is being output. That's completely backwards. Instead you should treat the transistor like a simple pushbutton and provide it with a pullup (or pulldown if you prefer) resistor, like this:
schematic
You should feed the signal into an interrupt-enabled pin (such as D2 on the Uno as shown) so that an interrupt can be used for capturing the incoming edge time. Better would be to use the Input Capture peripheral, but that is harder to program for as there is no (AFAIK) library for it.
Yes, it would be possible to use the internal pullup resistor of the input pin instead of an external one, however using an external one allows you to fine tune the resistance which, coupled with the gate capacitance of the input pin, forms a low-pass filter limiting the frequency range you can monitor. At 50Hz it shouldn't be a problem though, so the choice is yours. Personally I use an external one.
Majenko
  • 105,851
  • 82
  • 139
