I'm trying to datalog to a EyeFi SD card by writing to a file with a jpg extension. Here's that portion of my code so far:
// see if the directory exists, create it if not.
if( !SD.exists("/DCIM/100NIKON") )
  if( SD.mkdir("/DCIM/100NIKON") )
    Serial.print("File directory created: ");
  else {
    error("File directory not created");
else
  Serial.print("File directory exists: ");
// Test file
char filename[] = "DSCN0000.JPG";
if (! SD.exists(filename))
  logfile = SD.open(filename, FILE_WRITE); // only open a new file if it doesn't exist
if (! logfile)
  error("Couldnt create file");
The Arduino creates the directory, but the file is still saved to the root. I would love some help or tips on this.
user2218339
  • 219
You're creating a directory, and then not writing the file into it.
You need to change the filename to /DCIM/100NIKON/DSCN0000.JPG";
Note that SD.open() takes the full filepath to the file, not just the file*name*.
From the Arduino Docs:
The file names passed to the SD library functions can include paths separated by forward-slashes, /, e.g. "directory/filename.txt". Because the working directory is always the root of the SD card, a name refers to the same file whether or not it includes a leading slash (e.g. "/file.txt" is equivalent to "file.txt"). As of version 1.0, the library supports opening multiple files.
(emphasis mine)
Connor Wolf
  • 2,724
