I'm a beginner in Arduino world and I want to create a simple SD datalogger that works with GPS (module NEO-6M) and light sensor. I know there are a number of tutorials on GPS logging including:
- Create a GPS Data Logger Using The Arduino (Bob Cravens)
- Geo Data Logger: Arduino+GPS+SD+Accelerometer (Instructables)
- Making a SD card GPS logger with Arduino and MTK3329 GPS module (Arduinodev)
but my problem is that those tutorials are either too complex (i.e. include extra stuff like displays) or they don't use TinyGPS or TinyGPS++ library. In the first step I've managed to get GPS working and displaying the result on my laptop screen (via Serial.print()) using example code from TinyGPS library. In the next step I managed to use tutorial for Adafruit Data Logger to log data on SD card. The problem: light sensor logs ok, but for GPS it only logs a strings of 99.999999. Tried various tweaks but so far not sure what I got wrong. I use Arduino Uno, NEO-6M GPS, Catalex MicroSD Card Adapter, simple LDR. Here is my current code:
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include "SD.h"
//input for the light detecting sensor (LDR)
int LDR = A3;
//inputs and triggers for GPS
TinyGPSPlus gps;
SoftwareSerial ss (7, 8); // TX=7, RX=8
// digital pin 4 for the SD cs line
const int chipSelect = 4;
File logfile;// the logging file
//data logger timing and other
#define LOG_INTERVAL 1000 // mills between entries
#define SYNC_INTERVAL 1000 // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
#define ECHO_TO_SERIAL 1 // echo data to serial port
#define WAIT_TO_START 0 // Wait for serial input in setup()
Serial.begin(9600);
ss.begin(9600);
Serial.println();
#if WAIT_TO_START
Serial.println("Type any character to start");
while (!Serial.available());
#endif //WAIT_TO_START
// initialize the SD card
Serial.print("Initializing SD card...");
pinMode(10, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
// create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
Serial.print("Logging to: ");
Serial.println(filename);
logfile.println("date,time,lat,long,light");
#if ECHO_TO_SERIAL
Serial.println("lat,log,date,time,altitude,light");
#endif// attempt to write out the header to the file
void loop(void) {
// delay for the amount of time we want between readings
delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
//here is GPS data (if I got it right)
while (ss.available() > 0)
gps.encode(ss.read());
logfile.print(gps.date.value());
logfile.print(", ");
logfile.print(gps.time.value());
logfile.print(gps.location.lat(), 6);
logfile.print(gps.location.lng(), 6);
#if ECHO_TO_SERIAL
Serial.print(gps.date.value());
Serial.print(", ");
Serial.print(gps.time.value());
Serial.print(", ");
Serial.print(gps.location.lat(), 6);
Serial.print(", ");
Serial.print(gps.location.lng(), 6);
Serial.print(", ");
#endif
//Read light intensity
float lux = 500/(10.72/(5-(photocellReading * 0.00488759))*(photocellReading * 0.00488759));
logfile.println(lux);
#if ECHO_TO_SERIAL
Serial.println(lux);
#endif //ECHO_TO_SERIAL
//write data to disk
if ((millis() - syncTime) < SYNC_INTERVAL) return;
syncTime = millis();
logfile.flush();
