I have an LSM9DS1 breakout board by Sparkfun, and am communicating with it using a Mega 2560 over I2C. The board is given 3.3 V power as defined in the data sheet, though there seems to be confusion whether the SDA and SCL pins need level shifting for communicating with the 5 V Mega. In theory it shouldn't need to.
I am able to connect with the device and get its accelerometer and magnetometer data, however the gyro is just returning noise and no signal. I have dug in to all the registers I know of regarding high pass filters, logging rates, enabling and powering the sensor, but the only hints are that when the gyro is disabled and then polled, it returns a constant nonzero value on all three axes, as though a bit somewhere is stuck. With any other setting the results are unchanged: finite noise on a constant DC signal. Is this even possible? How can I dig deeper to understand and solve this problem?
J Collins
  • 295
In theory you must use a level shifter for SDA and SCL. The Arduino Mega 2560 board has internal pullup resistors of about 50k for SDA and SCL and extra 10k pullup resistors of 10k to 5V and according to the datasheet the ATmega2560 requires 3.5V to detect a high level for the I2C bus.
Those pullup resistors might damage the LSM9DS1.
5V-3.3V / 50k//10k times two (both SDA and SCL) = 400nA that might be pushed into the sensor (I assume there are protection diodes, and the maximum voltage is 3.6V, therefor the 400nA is just an indication). I assume the 10k pullup resistors to 3.3V on the sensor module are enabled. They will take away some over-voltage.
The current by the pullup resistors (to 5V) is a very small current, and I don't know if the sensor is in sleep mode during startup.
To be sure you need to buy another LSM9DS1 and a level shifter. Or even better: buy a 3.3V Arduino board, like the Due or the Zero, M0, and so on.
Have to compared the raw sensor data with others ? Those sensors are very noisy. That is why there is so much to do about filter algoritms to get data that can actually be used. The LSM9DS1 does not do processing or smart filtering with the raw data. All you get is the raw data. Did you assume that the values would be zero ? They never will be, because such sensors are far too noisy and too sensitive for that.
Jot
  • 3,276
