Okay so I did this project from Fritzing first in my circuits.io project then on the arduino itself, it all works fine just how I wanted it.
But here is what I wanted to add, as you can see when you plug the arduino in it will set the time to 00:00 and you can adjust it yourself to the time right now, let's say 12:57. Then you put in the alarm so let's say you want to sleep an hour u put the alarm on 13:57.
Is there a way to automatically get the time from the computer? So you don't have to adjust it yourself everytime and start from 00:00.
Thanks for all the help!
Zanic L3
  • 181
There are several ways, and they are covered in the comments above.
  1. The answer to your question. Via Arduino USB to serial interface. and a simple batch file on a windows computer example:
    @echo off
    set datetimef=%time:~0,2%.%time:~3,2%:%time:~6,2%
    echo %datetimef% > COM5
COM5 is used as a example, your serial port can be another number.
The format in the example is hour.minute:second
MatsK
  • 1,366
