I'm designing an Arduino style board with built-in LEDs for several of the pins. To simplify assembly of the board and save on components, I was wondering whether it would be safe for those LEDs to share a single resistor, as in this diagram:
Obviously, the power dissipated through the resistor (3mA per pin @ 3V) is not a real problem. The reason I was hesitating is that LEDs in a parallel configuration should not share resistors, but is it safe to think that separate microcontroller pins don't count as a common anode, even if both pins are high?
