I have problem with baud rate. I have changed baud rate of esp from 115200 to 9600 with AT command AT+CIOBAUD. And everything worked fine until I wanted to change it back and executed command AT+CIOBAUD115200, after which everything I send trough arduino IDE serial monitor to ESP I get gibberish. I have tried all baud rated available in serial monitor but got nothing. Wiring stayed the same.
TX -> arduino RX
RX -> arduino TX
GND -> GND
CH_PD -> 3,3V
VCC -> 3,3V
I thought that if I can flash ESP firmware it will get back all default parameters, hence I tried flow these steps (link) but I stopped when executed esptool.py --port /dev/ttyACM0 erase_flash which got me
esptool.py v1.3
Connecting...................
A fatal error occurred: Failed to connect to ESP8266: Invalid head of packet ('\x00')
In some forums is said that to get rid of error I need to change baud rate, but nothings works for me.
Please advise how can I fix this problem.
Austris
  • 119
