I altered code for the Simple Simon says to work with a Midi controller instead of push buttons. i am having trouble with the input of the song sequence with the Midi Controller. during the time where the code is waiting for input from the Midi controller waitForButton(int delay) the notes being inputted should sound but it dose not . i need help in figuring this out. any advice would be appreciated. Here's my code :https://pastebin.com/dV73eF9U
const int PLAY = 1;
const int TRYAGIN = 2;
long currentMillis = 0;
long previousMillis = 0;
int state;
void songlearn(int tune);
void showsequence();
void readsequnce();
void incorrect();
int tune;
  if (state == PLAY) {
    showsequence();
    readsequnce();
  else if (state == TRYAGIN) {
    incorrect();
    state = PLAY;
void MyHandleNoteOn(byte channel, byte pitch, byte velocity) {
  data1 = MIDI.getData1();
  if (data1 == 48) { //C3
    Status[0][0] = 1;
    noteOn(0, data1, 100);
    input[0] = data1;
  if (data1 == 49) { //C3#
    Status[0][1] = 1;
    input[1] = data1;
  if (data1 == 50) { //D3
    Status[0][2] = 1;
    input[2] = data1;
  if (data1 == 51) { //D3#
    Status[0][3] = 1;
    input[3] = data1;
  if (data1 == 52) { //E3
    Status[0][4] = 1;
    input[4] = data1;
  if (data1 == 53) { //F3
    Status[1][0] = 1;
    input[5] = data1;
  if (data1 == 54) { //F3#
    Status[1][1] = 1;
    input[6] = data1;
  if (data1 == 55) { //G3
    Status[1][2] = 1;
    input[7] = data1;
  if (data1 == 56) { //G3#
    Status[1][3] = 1;
    input[8] = data1;
  if (data1 == 57) { //A3
    Status[1][4] = 1;
    input[9] = data1;
  if (data1 == 58) { //A3#
    Status[2][0] = 1;
    input[10] = data1;
  if (data1 == 59) { //B3
    Status[2][1] = 1;
    input[11] = data1;
  if (data1 == 60) { //C4
    Status[2][2] = 1;
    input[12] = data1;
  if (data1 == 61) { //C4#
    Status[2][3] = 1;
    input[13] = data1;
  if (data1 == 62) { //D4
    Status[2][4] = 1;
    input[14] = data1;
  if (data1 == 63) { //D4#
    Status[3][0] = 1;
    input[15] = data1;
  if (data1 == 64) { //E4
    Status[3][1] = 1;
    input[16] = data1;
  if (data1 == 65) { //F4
    Status[3][2] = 1;
    input[17] = data1;
  if (data1 == 66) { //F4#
    Status[3][3] = 1;
    input[18] = data1;
  if (data1 == 67) { //G4
    Status[3][4] = 1;
    input[19] = data1;
  if (data1 == 68) { //G4#
    Status[4][0] = 1;
    input[20] = data1;
  if (data1 == 69) { //A4
    Status[4][1] = 1;
    input[21] = data1;
  if (data1 == 70) { //A4#
    Status[4][2] = 1;
    input[22] = data1;
  if (data1 == 71) { //B4
    Status[4][3] = 1;
    input[23] = data1;
  if (data1 == 72) { //C5
    Status[4][4] = 1;
    input[24] = data1;
void MyHandleNoteOff(byte channel, byte pitch, byte velocity) {
    Status[0][0] = 0;
    noteOff(0, data1, 100);
    input[0] = 0;
    Status[0][1] = 0;
    input[1] = 0;
    Status[0][2] = 0;
    input[2] = 0;
    Status[0][3] = 0;
    input[3] = 0;
    Status[0][4] = 0;
    input[4] = 0;
    Status[1][0] = 0;
    input[5] = 0;
    Status[1][1] = 0;
    input[6] = 0;
    Status[1][2] = 0;
    input[7] = 0;
    Status[1][3] = 0;
    input[8] = 0;
    Status[1][4] = 0;
    input[9] = 0;
    Status[2][0] = 0;
    input[10] = 0;
    Status[2][1] = 0;
    input[11] = 0;
    Status[2][2] = 0;
    input[12] = 0;
    Status[2][3] = 0;
    input[13] = 0;
    Status[2][4] = 0;
    input[14] = 0;
    Status[3][0] = 0;
    input[15] = 0;
    Status[3][1] = 0;
    input[16] = 0;
    Status[3][2] = 0;
    input[17] = 0;
    Status[3][3] = 0;
    input[18] = 0;
    Status[3][4] = 0;
    input[19] = 0;
    Status[4][0] = 0;
    input[20] = 0;
    Status[4][1] = 0;
    input[21] = 0;
    Status[4][2] = 0;
    input[22] = 0;
    Status[4][3] = 0;
    input[23] = 0;
    Status[4][4] = 0;
    input[24] = 0;
//Send a MIDI note-on message.  Like Pressing a piano key
void noteOn(byte channel, byte note, byte attack_velocity) {
  talkMIDI( (0x90 | channel), note, attack_velocity);
//Send a MIDI note-off message.  Like releasing a piano key
void noteOff(byte channel, byte note, byte release_velocity) {
  talkMIDI( (0x80 | channel), note, release_velocity);
//Plays a MIDI note. Doesn't check to see that cmd is greater than 127, or that data values are less than 127
void talkMIDI(byte cmd, byte data1, byte data2) {
  mySerial.write(cmd);
  mySerial.write(data1);
  //Some commands only have one data byte. All cmds less than 0xBn have 2 data bytes
  //(sort of: http://253.ccarh.org/handout/midiprotocol/)
  if ( (cmd & 0xF0) <= 0xB0)
    mySerial.write(data2);
void playNote(int midi, int row, int col, int len, bool short_led = false)
  int len1, len2;
  if (short_led) {
    len1 = len * 3 / 4;
    len2 = len * 1 / 4;
  } else {
    len1 = len;
    len2 = 0;
  noteOn(0x90, midi, 100);
  digitalWrite(LedR[row], HIGH);
  digitalWrite(LedC[col], LOW);
  delay(len1);
  digitalWrite(LedR[row], LOW);
  digitalWrite(LedC[col], HIGH);
  delay(len2);
  noteOff(0x90, midi, 0);
void songlearn (int tune) {
  if (tune == 1) {
    lcd.clear();
    lcd.setCursor(4, 0);
    lcd.print("Learning Song :");// Print a message to the LCD.
    lcd.setCursor(1, 1);
    lcd.print(menuP1);
    //Plays Mary Had a Little Lamb on a loop at 145 BPM
    //Bar 1
    note[0] = 0x40;
    note[1] = 0x3e;
    note[2] = 0x3c;
    note[3] = 0x3e;
    //Bar 2
    note[4] = 0x40;
    note[5] = 0x40;
    note[6] = 0x40;
    //Bar 3
    note[7] = 0x3e;
    note[8] = 0x3e;
    note[9] = 0x3e;
    //Bar 4
    note[10] = 0x40;
    note[11] = 0x43;
    note[12] = 0x43;
    //Bar 5
    note[13] = 0x40;
    note[14] = 0x3e;
    note[15] = 0x3c;
    note[16] = 0x3e;
    //Bar 6
    note[17] = 0x40;
    note[18] = 0x40;
    note[19] = 0x40;
    note[20] = 0x40;
    //Bar 7
    note[21] = 0x3e;
    note[22] = 0x3e;
    note[23] = 0x40;
    note[24] = 0x3e;
    //Bar 8
    note[25] = 0x3c;
    //End song
void (*SongSeq[x])() =
{ //Bar 1
  [] { playNote(0x40, 3, 1, 414); } ,//Quarter note: E
  [] { playNote(0x3e, 2, 4, 414); } ,//Quarter note: D
  [] { playNote(0x3c, 2, 2, 414); } ,//Quarter note: C
  //Bar 2
  [] {playNote(0x40, 3, 1, 414, 1);} , //Quarter note: E
  [] {playNote(0x40, 3, 1, 414, 1); }, //Quarter note: E
  [] {playNote(0x40, 3, 1, 828, 1); }, //Half note: E
  //Bar 3
  []{playNote(0x3e, 2, 4, 414, 1);}, //Quarter note: D
  []{playNote(0x3e, 2, 4, 828, 1);}, //Half note: D
  //Bar 4
  []{playNote(0x40, 3, 1, 414);}, //Quarter note: E
  []{playNote(0x43, 3, 4, 414, 1);}, //Quarter note: G
  []{playNote(0x43, 3, 4, 828, 1);}, //Half note: G
  //Bar 5
  []{playNote(0x3e, 2, 4, 414);}, //Quarter note: D
  []{playNote(0x3c, 2, 2, 414);}, //Quarter note: C
  //Bar 6
  []{playNote(0x40, 3, 1, 414, 1);}, //Quarter note: E
  //Bar 7
  //Bar 8
  []{playNote(0x3c, 2, 2, 1656);}, //Whole note: C
  //End song
void showsequence() {
  //Add a new index to the end of the songseq
  SongSeq[largestindex];
  largestindex++;
  //loop through the songseq
  for (int index = 0; index < largestindex; index++) {
    SongSeq[index]();
void readsequnce() {
  bool mademistake = false;
  int key;
  for (int index = 0; index < largestindex & mademistake == false; index++) {
    key = waitForButton(5000);
    if (key == -1 | key != note[index]) {
      mademistake = true;
      SongSeq[index]();
      SongSeq[index]();
      state = 2;
int waitForButton(int delay)
  int keyPressed = -1;
  int check;
  boolean keyBackUp = false;
  currentMillis = millis();      // The number of ms since the program started running
  previousMillis = currentMillis;   // Records the point when we start spinning the loop.
  // Keep spinning the loop until "delay" seconds have passed.
  while (currentMillis - previousMillis < delay & keyBackUp == false)
    // Read the button and record when it has been pushed down.
    for (int i = 0; i < 25 & keyBackUp == false; i++)
      if (input[i] != 0)
        keyPressed = input[i];
        // Show the LED pushed.
        noteOn(0, keyPressed, 100);
        //  digitalWrite(leds[pin], HIGH);
        // It is possible the button is still being pushed.
        // This loop spins until the button is let up.
          check = input[i];
          if (check == 0)
            keyBackUp = true;
        // Turn the LED pushed off.
        noteOff(0, keyPressed, 0);
        // digitalWrite(leds[pin], LOW);
        // See if they took to long.
        if (currentMillis - previousMillis > delay)
          keyPressed = -1; // They took to long to let the button up so they lose.
  return keyPressed;
Hjhk90
  • 291
I notice that nothing in the code you posted calls the MyHandleNoteOn() function, which is the only thing that reads MIDI data in the code you posted.
The waitForButton() function where you say you're having the problem never does any input or output, it simply checks to see if something else has changed the input array. MyHandleNoteOn() above does change it.
This leads me to believe that code you haven't posted sets up an interrupt handler that calls MyHandleNoteOn() (and probably MyHandleNodeOff()). If that doesn't mean anything to you, the main problem here is that the program is a bit beyond your abilities and you need to start learning on something simpler. If it does mean something to you, the problem here is that the program is rather badly written and you need to write something simpler to practice using interrupts and shared memory communication.
Have you written simpler programs before that read MIDI events, do a bit of processing, and play back things based on that? Building a Simon Says game on top of that would be a good learning project.
cjs
  • 594
