Here's my circuit:
And the code:
//pins
const int control1 = 2;
const int control2 = 3;
const int enable = 9;
const int pinDirection = 4;
const int pinOnOff = 5;
const int pot = A0;
//states
int stateOnOff = 0;
int stateOnOffPrev = 0;
int stateDirection = 0;
int stateDirectionPrev = 0;
int motorEnabled = 0;
int motorSpeed = 0;
int motorDirection = 1;
void setup(){
  pinMode(pinDirection, INPUT);
  pinMode(pinOnOff, INPUT);
  pinMode(control1, OUTPUT);
  pinMode(control2, OUTPUT);
  pinMode(enable, OUTPUT);
  digitalWrite(enable, LOW);
  Serial.begin(9600);
void loop(){
  stateOnOff = digitalRead(pinOnOff);
  delay(10);
  stateDirection = digitalRead(pinDirection);
  motorSpeed = analogRead(pot)/4;
  if(stateOnOff != stateOnOffPrev){
    if(stateOnOff == HIGH){
      motorEnabled = !motorEnabled;
  if(stateDirection != stateDirectionPrev){
    if(stateDirection == HIGH){
      motorDirection = !motorDirection;
Serial.println(stateDirection);
  if(motorDirection == 1){
    digitalWrite(control1, HIGH);
    digitalWrite(control2, LOW);
  }else{
    digitalWrite(control1, LOW);
    digitalWrite(control2, HIGH);
  if(motorEnabled == 1){
    analogWrite(enable, motorSpeed);
  }else{
    analogWrite(enable, 0);
  stateDirectionPrev = stateDirection;
  stateOnOffPrev = stateOnOff;
As you can see, the switch on pin 5 controls whether the motor is on and the potentiometer controls motor speed. Both work.
However, when the switch on pin 4 is closed the stateDirection variable still reads 0, or open circuit. It should when pressed change the direction of the motor via the H-bridge. I've tried everything I could, new switches, higher resistance. The only time it read HIGH is when I literally plugged switch out to GND.
Serial shows stateDirection as an unending chain of zeroes.
And finally the schematics from the original project. schematics
Thank you.
**PS: Forgive for lack of comments! But I think a good Arduino programmer should not need comments. **
Roman
  • 211
you could have pull-up enabled on that pin: with a nominal value of 50k, 10k pull-down is just on the cusp of making it a logic low.
solution?
1) disable pull-up; 2) use a stronger pull-down; 3) get rid of the pull-down and rely on the pull-up alone. ...
dannyf
  • 2,813
If it shows low when bypassing switch and jumping to ground.. Then either bad switch or maybe simply wrong orientation of switch.
Edit: if GND is making pin 5 HIGH in logic, then your button needs to jump to GND and have the resistor on 5v. Currently it is opposite according to your schematic.
