I have made a very short version of my code. It has the basic problem I am facing. I explain my code and problem below.
#include <Adafruit_RGBLCDShield.h>
#include <utility/Adafruit_MCP23017.h>
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
lcd.begin(16, 2); //format of display
int menu = 0;
int subMenu = 99;
uint8_t buttons = lcd.readButtons();
lcd.setCursor(0,0);
if (menu == 0) {
lcd.print("Select menu option");
if (buttons & BUTTON_SELECT) {
lcd.clear();
menu = 99;
subMenu = 1;
if (subMenu == 1) {
lcd.print("in sub menu 1");
lcd.clear();
lcd.setCursor(0,1);
lcd.print("shouldnt happen");
I am setting a variable menu, which will keep track of what main menu I am on, and a subMenu, which keeps track of what sub-menu I am on.
The default value of menu (0) prints on the LCD "Select Menu Option".
When pressing SELECT, the LCD is cleared. The menu is being set to an unknown number, so that it doesn't print anything, and subMenu is set to 1.
If subMenu is equal to 1 (which it will be if the user chooses presses SELECT), the LCD prints "in sub menu 1".
Inside this, if the button SELECT is clicked, it should print "shouldnt happen".
The issue I am facing is that when clicking SELECT for entering the menu 1, the SELECT is also carried out to the sub-menu, so instead of waiting for a second key press to confirm going into the sub menu, it goes straight into it.
This makes sense because it is check that SELECT has been pressed, prints a new page, with the button SELECT still having been pressed, so it validated the condition for key press in the sub menu as well.
The user input to LCD display response should be the following:
Select menu option -> presses SELECT -> in sub menu 1 -> presses SELECT -> shouldnt happen
Currently however, it is like this:
Select menu option -> presses SELECT -> in sub menu 1 shouldnt happen
How can I make it so that these key presses only act on the menu on which they are?
Thanks, let me know if something confuses you, I can explain in more details
