Questions:
- Does the conversion of the ADC count to voltage depend on the actual voltage of the +5 V pin?
- If yes, what is the accepted method of getting that voltage from the board?
Background/Detail:
I have a circuit in which I have an Arduino Nano (clone) running from a USB connector (from a hub). The job of the Arduino is to measure the voltage on a battery which will drive a second circuit switched on/off by the Nano. For reference it is a battery tester.
There is a Nokia 5110 screen which displays the voltage from the very simple sketch below.
Serial.begin(9600);
display.begin();
// Init done
// You can change the contrast around to adapt the display
// for the best viewing!
display.setContrast(50);
// Text display tests
display.setTextSize(1);
display.setTextColor(BLACK);
display.clearDisplay(); // Clears the screen and buffer
display.setCursor(0,0);
display.print("Vin=");
int rawVIN = analogRead(VIN);
float floatVin = (rawVIN*4.75)/1023.0;
display.println(floatVin);
Serial.println(rawVIN);
display.display();
delay(1000);
- I measured the voltage of the battery using a DVM and it is 4.13 V, yet the Nano reports 4.35 V.
- I have a common ground between the battery and Arduino.
- Because the connection to test the voltage can float, I have a pulldown resistor to stop wild fluctuations (>10 kΩ)
After some investigation I found that the +5 V was actually outputting 4.75 V and changed my sketch from
float v = (rawVIN*5.0)/1024.0;
to
float v = (rawVIN*4.75)/1024.0;
and the voltage reading on the Arduino was now correct. I did this not because I understand what I did, I did it because I had a hunch it might change the value to the correct one.
