Can I use the TX/RX on pins 0, 1 (to a serial slave device) while also having the USB port dedicated PC communication?
101
  • 215
32u4 is multi-serial uC. USB connection works on default serial communication which can be used via Serial.print("somevalue"). On the other hand if you want to use RX/TX on pins 0, 1 which are actually RXD1 and TXD1. So, if you use Serial1.print("somevalue"). So the answer is a yes. You can use USB and RX/TX (hardware serial) at the same time.
Sener
  • 394
