I am new here and perhaps you could help me. I am trying to program Attiny13 with the following short sketch which uses ADC (analogread()) function, that is supposed to work like this:
- reads voltage from voltage divider using photoresistor - analogread() from A1 (ADC1)
- turns LED on/off whenever there is low light (covering photoresistor) - digitalwrite() LED at 3 (PB3)
however it does not work on each of the ADCs: - works when I use A3 (ADC3) as analogread - does not work when I use A1 (ADC1) or A2 (ADC2) as analogread
Do you know what might be the reason? Same code, but works on 1 of the ADCs only.
I program uC with USBASP programmer, but I don't think this matters since with 1 of the ADCs all works fine. Also it works on Arduino Mega 2560 and uC Atmega88, so something wrong with Attiny13.
Sketch that does not work:
int state = 0;
void setup()
pinMode(3, OUTPUT);
void loop()
int reading = analogRead(A1);
if (reading < 100) // ONCE I COVER PHOTORES. IT GOES INTO THIS LOOP AND TURNS ON/OFF THE LED
state = !state;
digitalWrite(3, state);
delay(200);
delay(100);
