I'm having some trouble wrapping my head around timers in Arduino. I've got a FSR Pressure Sensor and I want it to turn on my NeoPixel LED after pressing on it for 5 seconds. Any help is much appreciated!
My goal: FSRReading > 1022 then wait 5 seconds, turn on NeoPixel FSRReading < 1022, then reset timer, turn off NeoPixel
This is what I currently have for my code, I can detect and act on sensor readings, but no timer:
#include <Adafruit_NeoPixel.h>
#define PIN 6
#define NUMPIXELS 16
#include "Timer.h"
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int fsrPin = 9; // FSR is connected to analog 0
int fsrReading; // the analog reading from the FSR resistor divider int LEDbrightness;
int LEDbrightness;
Timer t;
void setup(void) {
Serial.begin(9600);
pixels.begin();
void loop(void) {
fsrReading = analogRead(fsrPin);
Serial.println(fsrReading);
Serial.print("Analog reading = ");
// we'll need to change the range from the analog reading (0-1023) down to the range // used by analogWrite (0-255) with map!
LEDbrightness = map(fsrReading, 0, 1023, 0, 255);
if (fsrReading < 10) {
Serial.println(" - No pressure"); } else if (fsrReading < 200) {
Serial.println(" - Light touch"); } else if (fsrReading < 500) {
Serial.println(" - Light squeeze"); } else if (fsrReading < 800) {
Serial.println(" - Medium squeeze"); } else {
Serial.println(" - Big squeeze"); }
delay(50);
for(int i=0;i<NUMPIXELS;i++){
// pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
if (fsrReading>1022){
pixels.setPixelColor(i, pixels.Color(0,255,0));
} else if (fsrReading<1022) {
pixels.setPixelColor(i, pixels.Color(0,0,0));
pixels.show(); // This sends the updated pixel color to the hardware.
