As the title alludes to, I'm in the process of converting an Arduino sketch to a Processing sketch. So far, mostly pretty straightforward.
I'm running into an issue with creating an array of ints for the channels for two muxers. Below is the code that I currently have working for the Arduino sketch:
int writeMux(int channel){
  int controlPin[] = {s0, s1, s2, s3, s4, s5, s6, s7};
  int muxChannel[20][8]={
    //Mux 1
    {0,0,0,0,0,0,0,0}, //channel 0
    {1,0,0,0,0,0,0,0}, //channel 1
    {0,1,0,0,0,0,0,0}, //channel 2
    {1,1,0,0,0,0,0,0}, //channel 3
    {0,0,1,0,0,0,0,0}, //channel 4
    {1,0,1,0,0,0,0,0}, //channel 5
    {0,1,1,0,0,0,0,0}, //channel 6
    {1,1,1,0,0,0,0,0}, //channel 7
    {0,0,0,1,0,0,0,0}, //channel 8
    {1,0,0,1,0,0,0,0}, //channel 9
    //Max 2
    {1,1,1,1,0,0,0,0}, //channel 0
    {1,1,1,1,1,0,0,0}, //channel 1
    {1,1,1,1,0,1,0,0}, //channel 2
    {1,1,1,1,1,1,0,0}, //channel 3
    {1,1,1,1,0,0,1,0}, //channel 4
    {1,1,1,1,1,0,1,0}, //channel 5
    {1,1,1,1,0,1,1,0}, //channel 6
    {1,1,1,1,1,1,1,0}, //channel 7
    {1,1,1,1,0,0,0,1}, //channel 8
    {1,1,1,1,1,0,0,1}, //channel 9
  //loop through the 4 sig
  for(int i = 0; i < 8; i ++){
    digitalWrite(controlPin[i], muxChannel[channel][i]);
  //write the value at the SIG pin
  analogWrite(SIG_pin, testValue);
  //return the value
  return 0;
Below is the slightly varied version that I'm using for my Processing-equivelent sketch.
int readMux(int channel){
  int controlPin[] = {s0, s1, s2, s3};
    //Mux 1
    //Max 2
  for(int i = 0; i < 4; i ++){
  arduino.analogWrite(SIG_pin, testValue);
  int val = 0;
  return val;
I'm currently getting an error of unexpected token: int error at the following line:
And, an error of The type of expression must be an array type but it resolved to int at this line:
Thank you!
narner
  • 267
