My ATTiny85 is connected to a 433 transmitter and an analog sound sensor. The 433 is working fine (using VirtualWire) but when I send the reading from the sensor all I receive is a 1.
What I would like to receive is the value between 0 and 1024 like when I print the sensor to serial. I cannot check it because the ATTiny85 had no serial out.
My code is a combination of snippets I found online, I am not happy with all the magic to format the data that needs sending. I would also like to send "Reading: 637" in stead of just the number but I find the concatenation Google results extremely complicated.
Should this code send the sensor data like 672? Could there maybe be some Fuse setting blocking the AnalogRead?
#include <VirtualWire.h>
const int transmit_pin = PB0;
const int sensor_pin = PB4;
int sensor_data;
char sensor_msg[4];
void setup()
  vw_set_tx_pin(transmit_pin);
  vw_setup(2000);
int count = 1;
void loop()
  sensor_data = analogRead(sensor_pin);
  itoa(sensor_data,sensor_msg,4);
  vw_send((uint8_t *)sensor_msg, strlen(sensor_msg));
  vw_wait_tx(); // Wait until the whole message is gone
  _delay_ms(1000);
  count = count + 1;
Receiver Code as requested
This is a Pro Mini (clone) and it has an LCD attached so I can see what is going on.
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,16,2);
const int receive_pin = 11;
char* testje;
void setup()
    delay(1000);
    Serial.begin(9600); // Debugging only
    Serial.println("setup");
    // Initialise the IO and ISR
    vw_set_rx_pin(receive_pin);
    vw_setup(2000);  // Bits per sec
    vw_rx_start();       // Start the receiver PLL running
    lcd.init();
    lcd.backlight();
    lcd.home();
    lcd.clear();
    lcd.print("hello");
    delay(1000);
    lcd.clear();
void loop()
  char buf[VW_MAX_MESSAGE_LEN];
  uint8_t buflen = VW_MAX_MESSAGE_LEN;
  if (vw_get_message(buf, &buflen)) {
    int i;
    // Message with a good checksum received, print it.
    Serial.print("Got: ");
    for (i = 0; i < buflen; i++) {
       Serial.print((char)buf[i]);
    Serial.println();
    Serial.println(buf);
    lcd.clear();
    lcd.print(buf);
Thijs
  • 432
I would double check the pin numbers for the attiny. They look like port bit numbers but that might just work by chance.
A quick double check with the attiny/pins_arduino.h give:
// ATMEL ATTINY45 / ARDUINO
// Ain0 (D5) PB5  1|    |8  Vcc
// Ain3 (D3) PB3  2|    |7  PB2 (D2) Ain1
// Ain2 (D4) PB4  3|    |6  PB1 (D1) pwm1
//           GND  4|    |5  PB0 (D0) pwm0
As you have found they should be defined as:
const int transmit_pin = 0; // Physical pin 5
const int sensor_pin = 4;   // and pin 3
This type of issue could be avoided by using strong data typing and object oriented design. Please see for instance Cosa ATtinyX5.hh and GPIO.hh.
Cheers!
Here is something that does basically the same as the sender. Cosa supports attiny and Arduino boards "out-of-the-box".
Mikael Patel
  • 7,989
