In this post, it was mentioned that to get the Arduino IDE to support an ATmega328 (only the ATmega328P is supported):
I should mention the Arduino way of doing this, is to create a new boards.txt file with this chip and add (not change) the avrdude.conf file. This will allow programing either from selecting the correct board. but that is another subject.
After a great deal of research in the past, and attempted modifications to boards.txt and avrdude.conf, I arrived at the conclusion that the Toolchain doesn't support the ATmega328 therefore the changes will have no effect.
Can anyone confirm that they have successfully found a way to make these changes, so we can avoid the need for a work-around?
Andy Tallack
  • 128
Please, Note that the Arduino IDE is behind on many of the tools. In this case avrdude and its conf file, along with avr-gcc
First:
.\arduino-1.5.6-r2\hardware\tools\avr\etc\avrdude.conf
needs to support the m328 in addition to m328p. This can be done by either updating
.\arduino-1.5.6-r2\hardware\tools\avr\bin\avrdude.exe
to something like avrdude-6.1-svn-20131205-mingw32. along with replacing the conf file with the new one
file that has both m328 along with the m328p. Note 6.1 supports a parent method, making it easy to duplicate chips with different signatures. Or use existing 5.11 and add to its
file by duplicating the entire m328p section and renaming the new entry to "m328" along with the correct signature.
Second:
avr-gcc need to be updated to support compiling both the m328p and m328. Yes, it just a semantic thing. But the next part will send either ATmega328p or ATmega328 to both gcc and dude. which both need to support it. One can simply copy over
with the new tool chain. I used avr-gcc-4.8_2013-03-06_mingw32
Third:
replace the following line in boards.txt
uno.build.mcu=atmega328p
with
## Arduino ATmega328P
uno.menu.cpu.atmega328p=ATmega328P
uno.menu.cpu.atmega328p.build.mcu=atmega328p
uno.menu.cpu.atmega328=ATmega328
uno.menu.cpu.atmega328.build.mcu=atmega328
This will add an option to the IDE when UNO is selected for either chip. And subsequently send the correct MCU to both the compiler and avrdude.
Proof:
Below are the verbose output of the IDE with the above changes. Note the -mmcu and -p for both options. As a real unit is was not connected it yielded the "not in sync" error. Where this shows it all works.
C:\projects\Arduino\arduino-1.5.6-r2\hardware\tools\avr\bin\avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=156 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\projects\Arduino\arduino-1.5.6-r2\hardware\arduino\avr\cores\arduino -IC:\projects\Arduino\arduino-1.5.6-r2\hardware\arduino\avr\variants\standard C:\Users\mflaga\AppData\Local\Temp\build6597836883576934105.tmp\sketch_jul31a.cpp -o C:\Users\mflaga\AppData\Local\Temp\build6597836883576934105.tmp\sketch_jul31a.cpp.o
C:\Users\mflaga\AppData\Local\Temp\build6597836883576934105.tmp/sketch_jul31a.cpp.hex
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
C:\projects\Arduino\arduino-1.5.6-r2/hardware/tools/avr/bin/avrdude -CC:\projects\Arduino\arduino-1.5.6-r2/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\mflaga\AppData\Local\Temp\build6597836883576934105.tmp/sketch_jul31a.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude done.  Thank you.
C:\projects\Arduino\arduino-1.5.6-r2\hardware\tools\avr\bin\avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -MMD -mmcu=atmega328 -DF_CPU=16000000L -DARDUINO=156 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\projects\Arduino\arduino-1.5.6-r2\hardware\arduino\avr\cores\arduino -IC:\projects\Arduino\arduino-1.5.6-r2\hardware\arduino\avr\variants\standard C:\Users\mflaga\AppData\Local\Temp\build6597836883576934105.tmp\sketch_jul31a.cpp -o C:\Users\mflaga\AppData\Local\Temp\build6597836883576934105.tmp\sketch_jul31a.cpp.o
C:\projects\Arduino\arduino-1.5.6-r2/hardware/tools/avr/bin/avrdude -CC:\projects\Arduino\arduino-1.5.6-r2/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328 -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\mflaga\AppData\Local\Temp\build6597836883576934105.tmp/sketch_jul31a.cpp.hex:i
mpflaga
  • 2,523
