it's possible to read value from a file inside sd card?
I'm trying to start with the sample code
  SD card read/write
 This example shows how to read and write data to and from an SD card file
 The circuit:
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4
 created   Nov 2010
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
File myFile;
  // Open serial communications and wait for port to open:
  Serial.begin(9600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  if (!SD.begin(53)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing1 1, 2, 3.");
    myFile.println("testing2 1, 2, 3.");
    myFile.println("testing3 1, 2, 3.");
    // close the file:
    myFile.close();
    Serial.println("done.");
  } else {
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
  // re-open the file for reading:
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println("test.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
      Serial.write(myFile.read());
    // close the file:
    myFile.close();
  } else {
  // nothing happens after setup
but here he read all the contnent of the file, i want to read only testing 3 part . Thank's for help
Francesco Valla
  • 376
i found this solution with use of strcmp: when i read the file i compare the result str coming from file flux
 SD card read/write
The circuit:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created   Nov 2010
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <SD.h>
File myFile;
char buf[10];
void setup()
 Serial.begin(9600);
  while (!Serial) {
   ; // wait for serial port to connect. Needed for Leonardo only
 // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
 // Note that even if it's not used as the CS pin, the hardware SS pin
 // (10 on most Arduino boards, 53 on the Mega) must be left as an output
 // or the SD library functions will not work.
  pinMode(10, OUTPUT);
   return;
 if (myFile) {
      myFile.read(buf,2);
       if(strncmp(buf, "12", 2) == 0)//for lenght i use 2 becouse im looking for a number with 2 digit
           Serial.println("Match!");
          break;
   // close the file:
   myFile.close();
 } else {
void loop()
Francesco Valla
  • 376
You have 2 options for doing this, depending on what exactly you want to read and how your file is arranged.
  1. Read from the beginning until you find what you want. Throw away (just don't keep) what you don't want.
  2. Use the File::seek(uint32_t) method to jump to a specific byte in the file and read from there. Only useful if you already know where in the file your data is.
Majenko
  • 105,851
  • 82
  • 139
