Hi fellow programmers,
I started to program Arduino a little deeply and popped out the following error when I was writing a class to read the pulses of a Hall effect flow rate sensor:
SensorDeVazao.cpp.o: In function `SensorDeVazao::Resetar()':
SensorDeVazao.cpp:141: undefined reference to `SensorDeVazao::SensorHandle'
SensorDeVazao.cpp.o:SensorDeVazao.cpp:141: more undefined references to `SensorDeVazao::SensorHandle' follow
collect2: error: ld returned 1 exit status
The code is divided in two files, a *.h and a *.cpp, so it is uncircumstantial to paste the code here (pos-edited: the codes are the following: *.h: codepad.org/UyLfik6W *.cpp: codepad.org/5KJmraCC). But I will explain the context:
SensorHandle is a static object of the own class SensorDeVazao (Brazilian Portuguese to FlowRateSensor) and it is used in an glue function used by the attachinterrupt to read the pulses I've mentioned previously. The function claimed in the error log ("Resetar", Brazilian Portuguese for reset) don't use the variable "SensorHandle". Last but not least, the message shown in the second line appears subsequently multiple times in the error window.
I hope, I provided all the informations to help you solve this issue. Thank you for the attention.
PS.: Sorry if this is a duplicated post. If yes, please forward it in the comments below.
