Can this DS18B20 sensor be used with Arduino internal pull-up or it require exactly 4.7k pull-up resistor?
Asked
Active
Viewed 5,463 times
The Arduino internal pull-up is something like 50k. That is a lot different from 4.7k. You would probably find that the pull-up is not strong enough to get clean pulses from the device. Also if you are using it in one-wire (parasitic) mode notice this from the datasheet:
To assure that the DS18B20 has sufficient supply current, it is necessary to provide a strong pullup on the 1-Wire bus whenever temperature conversions are taking place or data is being copied from the scratchpad to EEPROM.
Notice the words 'strong pullup'. The internal pullup is not strong.
Nick Gammon
- 38,901
- 13
- 69
- 125
If the datasheet specifies a 4.7kΩ resistor then a 4.7kΩ resistor is what you need.
Majenko
- 105,851
- 5
- 82
- 139
