10
I have following setup:
  • Arduino Duemilanove
  • Small water heater connected with optical relay (PWM is ok)
  • Waterproof DS18B20 temperature sensor
  • Unknown amount of water (but temperature sensor and heater are always underwater).
How can I accurately control water temperature, based on temperature sensor readings? By accurately, I mean up to accuracy of temperature sensor (in this case, ±0.5°C). Everything should run on Arduino, so no additional data storage or processing power is available. For debugging, I can obviously use computer.
I have tried running PID, but it seems really hard to
  1. Avoid overshooting - going over target temperature either initially, or when (cold) water is added
  2. Stabilize properly after adding cold water.
Paolo Zanchi
  • 951
  • 22
Olli
  • 265
You need to know the response time of your system and the repeatability of your measurements to characterize your data (establish confidence). I suggest taking samples and average them before turning the heater back on.
Imho, water will not happily stay within 0.5°C. Can you allow for coarse and fine modes? Use a higher PWM for great differences and then lower PWM for when close to target.
Once homed in on your target, there are a few means you can try to improve temperature stability. While pre-built things like PID work for many, I normally implement functionality like this manually.
Krista K
  • 526
