I am trying to integrate tone() with the open source program for the Amped heart rate monitor. The error:
Tone.cpp.o (symbol from plugin): In function `timer0_pin_port':
(.text+0x0): multiple definition of `__vector_7'
sketch\PulseSensorAmped_Arduino_1dot4.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
The program comes in three files. PulseSensorAmped_Arduino_1dot4.cpp I don't think references any timers but references a function in another file with this code:
  // Initializes Timer2 to throw an interrupt every 2mS.
  TCCR2A = 0x02;     // DISABLE PWM ON DIGITAL PINS 3 AND 11, AND GO INTO CTC MODE
  TCCR2B = 0x06;     // DON'T FORCE COMPARE, 256 PRESCALER
  OCR2A = 0X7C;      // SET THE TOP OF THE COUNT TO 124 FOR 500Hz SAMPLE RATE
  TIMSK2 = 0x02;     // ENABLE INTERRUPT ON MATCH BETWEEN TIMER2 AND OCR2A
  sei();             // MAKE SURE GLOBAL INTERRUPTS ARE ENABLED
This uses timer 2; but isn't the error for timer 1? The tone() reference page says that tone interferes with pins 3 and 11. Is there any way to fix this?
references:
https://www.arduino.cc/en/Reference/Tone
https://github.com/WorldFamousElectronics/PulseSensor_Amped_Arduino
rur2641
  • 291
It looks like the Tone library uses Timer 2, and it looks like your other code also uses Timer 2, hence the error message. Vector 7 would be the TIMER2_COMPA_vect (Timer 2 compare "a").
Pins 3 and 11 are from Timer 2.
I wrote a small library that generates tones using the hardware PWM and not interrupts. You can read about it here.
Example code:
#include <TonePlayer.h>
TonePlayer tone1 (TCCR1A, TCCR1B, OCR1AH, OCR1AL, TCNT1H, TCNT1L);  // pin D9 (Uno), D11 (Mega)
void setup()
  pinMode (9, OUTPUT);  // output pin is fixed (OC1A)
  tone1.tone (220);  // 220 Hz
  delay (500);
  tone1.noTone ();
  tone1.tone (440);
  delay (500);
  tone1.noTone ();
  tone1.tone (880);
  delay (500);
  tone1.noTone ();
void loop() { }
Library can be downloaded from http://www.gammon.com.au/Arduino/TonePlayer.zip
This uses Timer 1 (so that won't interfere with Timer 2) and no interrupts.
Nick Gammon
  • 38,901
