I got problems with the code and I have used most of today, trying to find a solution and it's starting to drive my crazy. I hope one of you guys will be able to help me out.
I need the code to check a specific page every 10 seconds, single character.
This is what I have now, working code: Where should I start?
#include <Ethernet.h>
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 104 };
char server[] = "billigefittings.dk";
EthernetClient client;
void setup()
  Ethernet.begin(mac, ip);
  Serial.begin(9600);
  delay(1000);
  Serial.println(Ethernet.localIP());
  Serial.println();
  Serial.println("connecting ...");
  if (client.connect(server, 80)) {
    Serial.println("connected");
    client.println("GET /lan.php");
    client.println();
  } else {
    Serial.println("connection failed");
void loop()
  if(client.available() > 0) {
    char c = client.read();
    Serial.print("page value:");
    Serial.println(c);
    if(c == '1') {
        digitalWrite(8, HIGH);
        Serial.println("8 HIGH ...");
        delay(5000);
        digitalWrite(8, LOW);
        Serial.println("8 LOW ...");
    }else{
        Serial.println("page value does not match '1' !");
    // The code above should run even 10 seconds
  if(!client.connected()) {
    Serial.println();
    Serial.println("disconnecting.");
    client.stop();
    for(;;);
Update: Edit the loop like the example below does not work either, it stops after the first loop (8 LOW):
void loop()
    Serial.println(c);
    if(c == '1') {
        delay(5000);
    }else{
    delay(5000);
As discussed in the comments, you need to connect to the client each time, not just once.
Here's my modified version of your code, which I hope will work -- I'm not set up to test it.
#include <SPI.h>
void setup()
  Serial.begin(9600);
  delay(1000);
  Serial.println();
void loop()
  // Connect to the server
    client.println();
  } else {
  // Wait a moment for data to arrive
  // Note: This is NOT a reliable way of doing it!
  delay(1000);
    Serial.println(c);
    if(c == '1') {
        delay(5000);
    }else{
  // Disconnect the client
  if(client.connected()) {
    Serial.println();
    client.stop();
  // Wait another 9s, which will give us a delay of roughly 10s
  delay(9000);
Mark Smith
  • 2,181
