There are many great examples of how to access information from an array on the net. I ran into a specific case that has me confused. I am using a library for attiny 85 TinyPpmReader.h. This is a simple library that will take PPM signals in from a RC receiver running in pulse position mode and allows you to attach to a pin to process input. Easy enough.
In the code below, I ran into some confusion when trying to access the data in the array. I am trying to filter out a single channel in the ppm stream and print the contents of only 1 channel (Original example prints 8 channels) and eventually map that value to a servo. (I pasted the serial monitor ouput at the end of the code)
I tried accessing the variable stored in the array like this:
void loop()
for(uint8_t Idx = 1; Idx <= TinyPpmReader.detectedChannelNb(); Idx++) /* From Channel 1 to Max detected */
if(TinyPpmReader.detectedChannelNb == [5]) //Is this channel 6 in index 0-7?
Serial.println(TinyPpmReader.width_us[5); // if so, print only index 5 containing channel 6 values
delay(500);
Example unedited sketch from library
#include <TinyPinChange.h>
#include <TinyPpmReader.h>
#include <Rcul.h>
#define PPM_INPUT_PIN 2
void setup()
Serial.begin(38400)
TinyPpmReader.attach(PPM_INPUT_PIN);
void loop()
Serial.print(F("* Period="));Serial.print((int)TinyPpmReader.ppmPeriod_us());Serial.println(F(" us *"));
Serial.print(F("ChNb="));Serial.println((int)TinyPpmReader.detectedChannelNb());
Serial.print(F("Ch"));Serial.print(Idx);Serial.print(F("="));Serial.print(TinyPpmReader.width_us(Idx));Serial.println(F(" us"));
delay(500);
The serial monitor prints this:
* Period=17928 us *
ChNb=8
Ch=1496 us
Ch=1744 us
Ch=896 us
Ch=1560 us
Ch=1640 us
Ch=1496 us
Ch=1536 us
Ch=1688 us
Any suggestions? It is probably something simple but I dont think I am googling the correct question to get the correct answer.
EDIT: That worked Mark!
New Code Mapping attempt (Compiles,does not work)
#include <TinyServo.h>
#include <Rcul.h>
int PPM_INPUT_PIN = TinyPpmReader.width_us(3); //<------- Doesn't work
//int potpin0 = 3; <--------- // This worked
int val0; // integer to store value
const byte SERVOS = 1; // how many servos do you have? up to 5 on ATTiny85 and 8 on ATtiny84/2313
const byte servoPin[SERVOS] = { 0 }; // what pins are your servos on?
// you have the option to give your servos nice names. 0 refers to the first servo pin above, 1 to the second, etc
#define PANSERVO 0
#define PPM_INPUT_PIN 2 <--------- //define pin for ppm input
void setup()
setupServos();
void loop()
val0 = analogRead(PPM_INPUT_PIN); <--------- // reads the value of the potentiometer (value between 0 and 1023) // reads the value of the 2nd potentiometer (value between 0 and 1023)
val0= map(val0, 1000, 2000, 0, 180);
// scale it to use it with the servo (value between 0 and 180)
moveServo(PANSERVO, val0);
delay(5); // waits for the servo to get there
