Your initial assumption "An ATmega microcontroller can be flashed by a C compiler and a USB dedicated device (ISP)." is wrong.
The C compiler converts the source code into assembly language. It is then passed to an assembler which converts it to object code. The linker then creates an ELF file from it all. That is then converted into a HEX file using objdump.
That HEX file is then loaded by another program, avrdude, which knows how to control the USB-connected programming device. That device then issues special instructions to the chip through the ISP port to copy the data loaded from the HEX file into the memory of the chip in the right way.
It's quite a complex procedure and you require some active component in the mix to do the job. Just connecting an SD card and hoping it will work is, I am sorry to say, a laughable concept. You require something that a) understands how to read data from an SD card and can interpret it, and b) knows how to program an ATMega through ISP.
It is possible to create something that does that, using another chip, such as another ATMega, and writing the software to do it. If you feel adventurous, of course. You would basically have created a stand-alone programmer, which has advantages when you want to do field upgrades, but is pointless when you are sat at your desk developing software.
