UPDATE: The issue turned out to be with my work laptop. Our IT department has them configured in such a way that the assignment of serial ports is different somehow. When I plugged in on my personal Macbook Pro it all worked perfectly.
I just got my first Arduino. Its an UNO R3. I'm running OS X 10.8.5 (Mountain Lion) and the Arduino IDE 1.0.5
Under Tools>Board I have Arduino Uno selected
Under Tools>Serial Port my options are:
  • /dev/tty.Bluetooth-Serial-1
  • /dev/cu.Bluetooth-Serial-1
  • /dev/tty.Bluetooth-Serial-2
  • /dev/cu.Bluetooth-Serial-2
  • /dev/tty.Bluetooth-Modem
  • /dev/cu.Bluetooth-Modem
  • /dev/tty.Bluetooth-PDA-Sync
  • /dev/cu.Bluetooth-PDA-Sync
I've tried all of them, but when I try to upload a sketch it fails. Most give the following error:
The two "modem" options return this message:
Serial port '/dev/tty.Bluetooth-Modem' already in use. Try quitting any programs that may be using it.
I'm at a loss. None of these serial ports seems correct but there aren't any other options.
Also under Tools>Programmer which option should I be using?
Jonathan Miller
  • 151
Have you hooked up your Arduino prior to pulling down the tools>Serial Port menu? I only see the port for my Arduino listed when it's actually connected and running. (And it's never one of the bluetooth ports.) I don't have my Arduino with me at the moment so I can't tell you exactly what it is.
Also note that on my MBP (running 10.9.4) I have to be sure to plug the USB cable into the CORRECT USB port. The other port maps to a different port in the list of serial ports.
Duncan C
  • 5,752
  • 30
Jonathan Miller
  • 151
