I'm not finding many resources out there. I already tried using new versions of "TFTv2.h" and "TFTv2.cpp", but I don't think much of anything changed in my output.
These are the libraries I'm trying to use. The sketch I'm trying to compile for the 101 is empty except for these lines and an empty setup() and loop().
#include <stdint.h>
#include <TFTv2.h>//For Seedstudio Touch
#include <SPI.h>
#include <SeeedTouchScreen.h>   //Seedstudio LCD touch screen Library File
#include <SD.h>//For Seedstudio Touch
#include <XBee.h>   //Zigbee Wireless transciever Library File
#include <Printers.h>   //Zigbee Wireless transciever Library File
Basically I need to know whether I need to find replacements or workarounds for these libraries. Compiling for the 101 in Visual Studio, I get a lot of output messages that I don't get when compiling for the Mega. I have more-or-less no idea what they mean.
I'll go ahead and paste the non-verbose output here. Thanks for your advice! Let me know if I should add the verbose output, and I'll post it right away.
output (non-verbose);
Compiling debug version of 'Arduino_101trial' for 'Arduino/Genuino 101'
Sd2Card.cpp:In member function 'uint8_t Sd2Card::readData(uint32_t, uint16_t, uint16_t, uint8_t*)
Sd2Card.cpp:379:12: warning: unused variable 'n' [-Wunused-variable]
:uint16_t n
SdFile.cpp:In static member function 'static uint8_t SdFile::make83Name(const char*, uint8_t*)
SdFile.cpp:261:15: warning: unused variable 'b' [-Wunused-variable]
:uint8_t b
SdFile.cpp:In member function 'uint8_t SdFile::rmRfStar()
SdFile.cpp:907:40: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
:if (curPosition_ != (32*(index + 1))) {
TFTv2.cpp:In member function 'void TFT::drawString(char*, short unsigned int, short unsigned int, short unsigned int, short unsigned int)
TFTv2.cpp:388:18: warning: value computed is not used [-Wunused-value]
:*string++
SeeedTouchScreen.cpp:In file included from
pins_arduino.h:39:14: error: 'uint8_t' does not name a type
:static const uint8_t SS   = 10
pins_arduino.h:40:14: error: 'uint8_t' does not name a type
:static const uint8_t MOSI = 11
pins_arduino.h:41:14: error: 'uint8_t' does not name a type
:static const uint8_t MISO = 12
pins_arduino.h:42:14: error: 'uint8_t' does not name a type
:static const uint8_t SCK  = 13
pins_arduino.h:44:14: error: 'uint8_t' does not name a type
:static const uint8_t SDA = 18
pins_arduino.h:45:14: error: 'uint8_t' does not name a type
:static const uint8_t SCL = 19
pins_arduino.h:46:14: error: 'uint8_t' does not name a type
:static const uint8_t LED_BUILTIN = 13
pins_arduino.h:48:14: error: 'uint8_t' does not name a type
:static const uint8_t A0 = 14
pins_arduino.h:49:14: error: 'uint8_t' does not name a type
:static const uint8_t A1 = 15
pins_arduino.h:50:14: error: 'uint8_t' does not name a type
:static const uint8_t A2 = 16
pins_arduino.h:51:14: error: 'uint8_t' does not name a type
:static const uint8_t A3 = 17
pins_arduino.h:52:14: error: 'uint8_t' does not name a type
:static const uint8_t A4 = 18
pins_arduino.h:53:14: error: 'uint8_t' does not name a type
:static const uint8_t A5 = 19
pins_arduino.h:55:14: error: 'uint8_t' does not name a type
:static const uint8_t ATN = 20
Arduino.h:In file included from
wiring_private.h:from
SeeedTouchScreen.cpp:from
SeeedTouchScreen.cpp:In member function 'Point TouchScreen::getPoint()
SeeedTouchScreen.cpp:94:25: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
:*portOutputRegister(yp_port) &= ~yp_pin
variant.h:in definition of macro 'portOutputRegister
:#define portOutputRegister(port)  (uint32_t*)port
SeeedTouchScreen.cpp:95:25: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
:*portOutputRegister(ym_port) &= ~ym_pin
SeeedTouchScreen.cpp:100:25: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
:*portOutputRegister(xp_port) |= xp_pin
SeeedTouchScreen.cpp:101:25: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
:*portOutputRegister(xm_port) &= ~xm_pin
SeeedTouchScreen.cpp:127:25: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
:*portOutputRegister(xp_port) &= ~xp_pin
SeeedTouchScreen.cpp:130:25: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
:*portOutputRegister(yp_port) |= yp_pin
SeeedTouchScreen.cpp:153:25: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
:*portOutputRegister(xp_port) &= ~xp_pin;            \\ Set X+ to ground
SeeedTouchScreen.cpp:154:25: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
:*portOutputRegister(ym_port) |=  ym_pin;            \\ Set Y- to VCC
SeeedTouchScreen.cpp:155:25: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
:*portOutputRegister(yp_port) &= ~yp_pin;            \\ Hi-Z X- and Y+
Error compiling libraries
LegitimateWorkUser
  • 131
So it looks like you have some warnings in Sd2Card.cpp, SdFile.cpp, TFTv2.cpp
For the most part you can ignore these warnings
As for SeeedTouchScreen.cpp it looks like you're getting Errors for pins. does not name a type means that uint8_t is not a type Visual Studio understands.
Then further down you're getting another warning for SeeedTouchScreen.cpp
Did you make sure that whatever board you're using is compatible with these libraries?
The Arduino Mega has 54 digital input/output pins (of which 14 can be used as PWM outputs), 16 analog inputs, 4 UARTs (hardware serial ports)
The 101 comes with 14 digital input/output pins (of which 4 can be used as PWM outputs), 6 analog inputs.
This means that if your libraries are designed for the Mega and no other board you will run into these errors
