I'm trying to use the Digispark as a Rubber Ducky but the Digispark is only usable with the US laylout. German keyboard layout is QWERTZ. Some keys can be changed, like y and z, but if there are [ or ] this isn't possible. Trying to define a [-key in DigiKeyboard.h displays a ΓΌ.
Does someone know a solution?
sa_leinad
  • 3,218
user28624
You can edit the file scancode-ascii-table.h in your DigiKeyboard library. It basically states which ASCII code corresponds to which keyboard scancode.
So if you try to print the ':' character but get a '>' instead, you know that in the above mentioned file at the ASCII position for ':' is the scancode for a '>'.
Using this, you can swap the scancodes around and basically create your own 'mapping'. For example, if you swap the values at ASCII 89, 90 and 121, 122 you for example solve the Y/Z switch.
However, I have not figured out how to correctly print a backslash. You might have to map that do a different ASCII character you don't need.
To add to this answer, there exists a workaround using mame82's duck2spark: https://github.com/mame82/duck2spark
Panki
  • 121
Solution is here: Python script to convert RubberDucky payloads to DigiSpark sketch with respect to choosen keyboard layout:
duck2spark
Btw: The keys '<' '|' and '>' are on NON-US-KEY-100 on German keyboard layout. The key has value 0x64 for USB HID and the right modifiers have to be set (f.e. ALT_GR for '|' ). You could send them using
DigiKeyboard.sendKeyStroke(key,modifier);
For details see USB HID usage tables
MaMe82
here is a library version of Digistump with german keyboard support https://github.com/adnanonline/DigistumpArduinoDe I adapted the keyboard library: digistump-avr/libraries/DigisparkKeyboard/DigiKeyboard.h to the german layout
