I´m using LowPower.h and PinChangeInt.h libraries to put my Arduino into the sleep mode every 8 seconds and then it wakes up, modifies a counter and it goes to sleep again, but also I need to wake it up when a button is pressed asynchronously.
I´ve reached to wake up the Arduino every 8 seconds using LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF) and, in other code, I´ve also reached to wake it up while it sleeps indefinitely with LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF) but I can´t combine that periodical awakening with the asynchronous awakening.
Here is my code:
void setup(){
    Serial.begin(9600);
    //Pines declaration
    loopsToSend = setTimeToSend();  //
    //The three async buttons
    PCintPort::attachInterrupt(4, readOpinion,RISING);
    PCintPort::attachInterrupt(5, readOpinion,RISING);
    PCintPort::attachInterrupt(6, readOpinion,RISING);
void loop(){
    if(loops < loopsToSend ){
        byte opinionValue = readOpinion(); //This method must awake the Arduino ASYNC to give a value to the opinionValue var, write the result in the file and go to sleep
        if(opinionValue != 0){
            Serial.println("Button pressed!");
            //Writing result in a file
            opiniones++;
            delay(500);
        //Go to sleep 8 seconds
        LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
        opinionValue = 0;
    else {
        wdt_disable();
        if(opiniones > 0){
            //Send file using GSM module
        else{
            loops = 0;
    loops++;
Can anyone help me? Thanks
Ghanima
  • 459
cpinamtz
  • 175
This one works for me:
#include <PinChangeInterrupt.h>
#include <LowPower.h>
// I want to know when it was interrupted by PCINT:
volatile byte flag = 0;
void handler() {
    flag = 1;
  Serial.begin(115200);
  pinMode(A0, INPUT_PULLUP);
  attachPCINT(digitalPinToPCINT(A0), handler, CHANGE);
  Serial.println("entering powerDown sleep mode");
  Serial.flush(); // wait for sending all data
  if (flag == 1) {
    flag = 0;
    Serial.println("Pin change interrupt");
  } else {
    Serial.println("Timeout");
However if you use RISING (or FALLING), it also wakes up from the sleep when pin changes back to the oposite state (and it'll be reported as Timeout).
KIIV
  • 4,907
