I am trying to run a clock off of an arduino following this site: http://www.cibomahto.com/2008/03/controlling-a-clock-with-an-arduino/comment-page-1/ and I tried to combine it with this to get it to run accurately. https://contractorwolf.com/arduino-pwm-interrupt-clock/
For the project that I want to do I need to slow down the minute hand by 23.9345 (So that it will run on sidereal time)
Now the bare code of the first link with some mods works perfectly, but the delay does not seem to be accurate:
const int a1 = 8; //use digital I/O pin 8
const int a2 = 9;
const int tick1 = 1000;
const int tick2 = 50;
void setup()
pinMode(a1,OUTPUT); //set pin 8 to be an output output
pinMode(a2,OUTPUT); //set pin 9 to be an output output
void loop()
delay(tick1); //delay 1000 milliseconds
digitalWrite(a1,HIGH); //set pin 8 HIGH, turning on LED
delay(tick2); //delay 1000 milliseconds
digitalWrite(a1,LOW); //set pin 8 LOW, turning off LED
digitalWrite(a2,HIGH); //set pin 9 HIGH, turning on LED
digitalWrite(a2,LOW); //set pin 9 LOW, turning off LED
For this reason I have tried to merge it with the 1 wire clock project and got
const int a2 = 9;
int cyclesPerSecond = 974;
//pins
int clockInterrupt = 0; //interrupt 0 is pin 2 on UNO
int pwmOut = 6; //pin 6
//timekeeping
int seconds = 0;
int masterClock = 0;//number of square waves
void setup()
attachInterrupt(clockInterrupt, clockCounter, RISING);
pinMode(a2,OUTPUT); //set pin 8 to be an output output
Serial.println(pwmOut);
analogWrite(pwmOut, 127); // this starts our PWM 'clock' with a 50% duty cycle//digital pin 10 for analogWrite pwm out
void clockCounter() // called by interrupt 0 (pin 2 on the UNO) receiving a rising clock edge PWM
masterClock ++; // with each clock rise add 1 to masterclock count
if(masterClock >= cyclesPerSecond*23.9345) // 974hz on pin 6, may be 490Hz if you use pin 9 or 10
seconds ++; // after one cycle add 1 second
masterClock = 0; //reset clock counter
void loop()
if (seconds == 1){
else if(seconds == 2)
seconds = 0;
However this does not seem to move the second hand properly, so the clock does tick but not strong enough to actually work. Is this a hardware thing or a processor thing? I have no idea why this would not work while the other code does.
