Trying to setup a server on Arduino to support multiple clients, I am able to support one but I don't want to flush that client to make another connection.
#include <ESP8266WiFi.h>
const char* ssid = "your-ssid";
const char* password = "your-password";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
  Serial.begin(115200);
  delay(10);
  // prepare GPIO2
  pinMode(2, OUTPUT);
  digitalWrite(2, 0);
  // Connect to WiFi network
  Serial.println();
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  // Start the server
  server.begin();
  Serial.println("Server started");
  // Print the IP address
  Serial.println(WiFi.localIP());
  // Check if a client has connected
  WiFiClient client = server.available();
  if (!client) {
    return;
  // Wait until the client sends some data
  Serial.println("new client");
  while(!client.available()){
    delay(1);
  // Read the first line of the request
  String req = client.readStringUntil('\r');
  Serial.println(req);
  client.flush();
  // Match the request
  int val;
  if (req.indexOf("/gpio/0") != -1)
    val = 0;
  else if (req.indexOf("/gpio/1") != -1)
    val = 1;
  else {
    Serial.println("invalid request");
    client.stop();
    return;
  // Set GPIO2 according to the request
  digitalWrite(2, val);
  client.flush();
  // Prepare the response
  String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now ";
  s += (val)?"high":"low";
  s += "</html>\n";
  // Send the response to the client
  client.print(s);
  delay(1);
  Serial.println("Client disonnected");
  // The client will actually be disconnected
  // when the function returns and 'client' object is detroyed
Using this code, the server handles only one client at a time, but I need to connect multiple clents simultaneously.
jfpoilpret
  • 9,162
  • 38
  • 54
user28203
  • 61
You need to keep track of multiple WiFiClients - declare an array of them, for example, and each time server.available() gives you a new one, store it in the array.
Then you need to make sure your code doesn't stick waiting for data from each item. You could service each WifiClient in turn: if it has data waiting (client[i].available() is true), read the data (client[i].read()) and store it. When you get a \r from a client, you know you have a whole line, and you can process it.
Here's a nearly-complete (but untested) example so you can see what I'm talking about. Naturally it's not the only way to do it.
#define MAX_CLIENTS 10
#define MAX_LINE_LENGTH 50
WiFiClient *clients[MAX_CLIENTS] = { NULL };
char inputs[MAX_CLIENTS][MAX_LINE_LENGTH] = { 0 };
  delay(10);
  // prepare GPIO2
  pinMode(2, OUTPUT);
  digitalWrite(2, 0);
  Serial.println();
  Serial.println();
    delay(500);
    Serial.print(".");
  Serial.println("");
  // Start the server
  server.begin();
  // Check if a new client has connected
  WiFiClient newClient = server.available();
  if (client) {
    // Find the first unused space
    for (int i=0 ; i<MAX_CLIENTS ; ++i) {
        if (NULL == clients[i]) {
            clients[i] = new WiFiClient(newClient);
            break;
  // Check whether each client has some data
    // If the client is in use, and has some data...
    if (NULL != clients[i] && clients[i]->available() ) {
      // Read the data
      char newChar = clients[i]->read();
      // If we have the end of a string
      // (Using the test your code uses)
      if ('\r' == newChar) {
        // Blah blah, do whatever you want with inputs[i]
        // Empty the string for next time
        inputs[i][0] = NULL;
        // The flush that you had in your code - I'm not sure
        // why you want this, but here it is
        clients[i]->flush();
        // If you want to disconnect the client here, then do this:
        clients[i]->stop();
        delete clients[i];
        clients[i] = NULL;
      } else {
        // Add it to the string
        strcat(inputs[i], newChar);
        // IMPORTANT: Nothing stops this from overrunning the string and
        //            trashing your memory. You SHOULD guard against this.
        //            But I'm not going to do all your work for you :-)
Mark Smith
  • 2,181
Here , I have used array of WiFiClient . The reason is array pointer will hold previous plus latest WiFiClients (emoteIP and remotePort ) and user will be able to choose which WIFiClient to be used for communication.
We can store IPAddress , Port as well as whole WiFiClient object in an array
       WebServer  Wserver(80);
       WiFiClient Wclient;
       WiFiClient *Wificlients[10] = { NULL };
       int  Clientindex=-1;
       Wclient = Wserver.client(); // or  server.avilable() if WiFiServer
       Wificlients[Clientindex++]=new WiFiClient(Wclient);
       int   cntloggedinclient=0;
       int kk=0;
       while(Wificlients[kk] != NULL)
               cntloggedinclient++;  // Total clients count
               kk++;
         // Multicasting bytes to all connected clients.
         int kkk =0;
         while(kkk<cntloggedinclient)
           Wificlients[kkk]->write((unsigned char*) &newbuff,len);
           kkk++;
I have a solution using RTOS Tasks, I think this is the best way to manage multiple clients at same time. I test this code in ESP32 dev module.
#if CONFIG_FREERTOS_UNICORE
#define ARDUINO_RUNNING_CORE 0
#else
#define ARDUINO_RUNNING_CORE 1
#endif
#include <WiFi.h>
const char* ssid = "[YOUR-NETWORK-SSID]"; const char* password = "[YOUR-SSID-PASSWORD]";
void TaskClientSocket( void *pvParameters );
WiFiServer wifiServer(80);
void setup() { // put your setup code here, to run once: Serial.begin(115200); delay(1000); WiFi.begin(ssid,password); Serial.println("Connecting to Wifi..."); while (WiFi.status() != WL_CONNECTED) { delay(1000); Serial.print("."); } Serial.println("Connected to WiFi network"); Serial.println(WiFi.localIP());
wifiServer.begin(); }
void loop() { WiFiClient client = wifiServer.available(); if( client){ Serial.println("New Client Connected..."); xTaskCreatePinnedToCore( TaskClientSocket , "TaskClientSocket" , 4098 , &client , 2
, NULL , ARDUINO_RUNNING_CORE); } }
void TaskClientSocket( void pvParameters ) { WiFiClient clientHandle = ((WiFiClient*)pvParameters); for (;;) { while(clientHandle.connected()){ while(clientHandle.available()>0){ char c = clientHandle.read(); clientHandle.write(c); } vTaskDelay(100); } clientHandle.stop(); Serial.println("Client disconnected"); vTaskDelete(NULL); } }
