I'm developing a project where I can control a RC boat with GPS and a magnetometer. How ever, I was developing everything connected to my computer and worked pretty well. When I was going to make some test with a battery and a couple of Xbee's (PC and "Arduino"), the magnetometer signal was not updating. So, I read the first value and continued to transmit the same value (thing that never happened on computer). Has someone had the same issue before? How can I solve this? Oh, one thing. The GPS and magnetometer comes in the same module, and I'm having no problems with GPS coordinates. And even if I power de MCU with my computer and transmitting with the Xbee's it doesn't work either. Seems like a communication problem.
Hardware used:
GPS Module + Compass
ATmega1284P
UPDATE:
I want to share also the code I'm using for the I2C reading.
#include <Wire.h> //I2C Arduino Library
#define address 0x1E //0011110b, I2C 7bit address of HMC5883
void setup(){
  //Initialize Serial and I2C communications
  Serial.begin(9600);
  Wire.begin();
  //Put the HMC5883 IC into the correct operating mode
  Wire.beginTransmission(address); //open communication with HMC5883
  Wire.send(0x02); //select mode register
  Wire.send(0x00); //continuous measurement mode
  Wire.endTransmission();
 void loop(){
  int x,y,z; //triple axis data
  //Tell the HMC5883L where to begin reading data
  Wire.send(0x03); //select register 3, X MSB register
 //Read data from each axis, 2 registers per axis
  Wire.requestFrom(address, 6);
  if(6<=Wire.available()){
    x = Wire.receive()<<8; //X msb
    x |= Wire.receive(); //X lsb
    z = Wire.receive()<<8; //Z msb
    z |= Wire.receive(); //Z lsb
    y = Wire.receive()<<8; //Y msb
    y |= Wire.receive(); //Y lsb
  //Print out values of each axis
  Serial.print("x: ");
  Serial.print(x);
  Serial.print("  y: ");
  Serial.print(y);
  Serial.print("  z: ");
  Serial.println(z);
I have solved the problem by adding a delay just before I select the continuous measurement mode.
void setup(){
  Serial.begin(9600);
  Wire.begin();
  delay(100);
There are 2 possible problems:
Lack of power or libraries not supporting each other.
1 - Try powering the circuit with some USB 5V. Make sure that your other modules can support 5V. Also check your clock speed. High clock speeds with low voltages might cause your ATmega to function incorrectly.
2 - Some libraries for certain module / breakout uses software I2C which pretty much emulate I2C. They might not be compatible with another module that needs the wire library to function proprely. To debug it, test out 1 module at the time with the battery.
Dat Ha
  • 2,943
  • 46
