I'm trying to communicate with my Arduiono UNO via USB serial port, more precisely I'm trying to read a string like 125,0, I know it's full of article out there about this, but belive me I've tryied more or less everything, now I got a NODEJS server on a Raspberry Pi that looks like:
var express = require('express');
app = express();
server = require('http').createServer(app);
io = require('socket.io').listen(server);
var SerialPort = require("serialport")
var serialPort = new SerialPort("/dev/ttyACM1", { baudrate: 115200 });
server.listen(8080);
app.use(express.static('public'));
var brightness1 = 0;
var brightness2 = 0;
var string;
io.sockets.on('connection', function (socket) {
    socket.on('led', function (data) {
        brightness1 = data.value1;
        brightness2 = data.value2;
        string = brightness1 +","+brightness2;
        var buf = new Buffer(1);
        buf.write(string);
        serialPort.write(buf);
        console.log(buf);
        console.log(string);
        io.sockets.emit('led', {value1: brightness1, value2: brightness2});
So based on that, I'm sending a string over the serial and the console log showed above gives me that:
<Buffer 32>    //console.log(buf);
23,0           //console.log(string);
Wich I think it should be ok because I'm sending what I need a 32 and a 0, also if i don't know what it means the
Arduino side I used the sketch provided here and retouch it a bit based on my needs:
void setup()
  Serial.begin(115200);
void loop()
  while(!Serial.available());   //wait until a byte was received
      Serial.println(Serial.read());
      int a = Serial.parseInt();
      int b = Serial.parseInt();
      Serial.println(a);
      Serial.println(b);
      //analogWrite(3, a);
but the result of my Serial.print() are really incongruents, something like: 5--2224, which is totally nosense, my question so is WHY? Where I'm getting wrong? I read a lot around, am I missing something?
FabioEnne
  • 233
This is a common (and my favorite) approach:
  • Choose an “end of message” character. CR or LF can be good choices, especially if you want to test your program with a terminal emulator.
  • On the Arduino, buffer all the received bytes until you see the end of message.
  • When you see the end of message, handle the buffer to a function that will parse and process it.
I would avoid parseInt() for anything but the simplest tests, because it is both blocking and sensitive to the timing of the input.
For an example, you can take a look at this Simple Arduino command line interpreter (look at loop()). It's non blocking, so you can add background processing to perform while waiting for input characters.
Edgar Bonet
  • 45,094
  • 81
I fully agree here with edgar Bonet.
I only want to add a link to a library I have written that does a line by line (based on end message CR and/or LF)
SerialStringReader This library contains examples.
Note that for many reasons the library uses null terminated strinsg (also known as char arrays) and not the Arduino String class
jantje
  • 1,392
How to correctly read a string from Arduino serial port?
You can use the function Serial.readString(). It will return a string that you typed from the serial monitor.
Dat Ha
  • 2,943
  • 46
