I am trying to create a simple piano playback using a flex sensor, a proximity sensor and a piezo buzzer.
I want to have it so that when the flex sensor is triggered, a sound is played on the piezo buzzer. The tone it makes is dependent on the values received from the proximity sensor.
Here is my code:
int psrAnalogPin = 6;
int fsrAnalogPin = 10;
int speaker = 9;
int fsrReading;
int psrReading;
void setup(void) {
  Serial.begin(9600);
  // We'll send debugging information via the Serial monitor
  pinMode(speaker, OUTPUT);
void loop(void) {
  psrReading = analogRead(6);
  delay(10);
  delay(10);
  Serial.print("\n psr reading = ");
  Serial.println(psrReading);
  fsrReading = analogRead(10);
  delay(10);
  delay(10);
  Serial.print("\n fsr reading : ");
  Serial.println(fsrReading);
  if(fsrReading < 980 && psrReading > 599){
    tone(9, 400, 1000);
  } else if (fsrReading < 980 && psrReading > 500){
    tone(9, 500, 1000);
  } else if (fsrReading < 980 && psrReading < 392){
    tone(9, 600, 1000);
When I look at the serial monitor's output, the values output seem to be only reading from my flex sensor(fsrReading) and not my proximity sensor. If I only read the proximity sensor's value it works, but not both at the same time.
How can I get it so that it reads both values instead of just one?
dda
  • 1,595
Eddie
This is not a full code but more of an explanation of the logic of your program.
when the flex sensor is triggered, a sound is played on the piezzo buzzer. The tone it makes is dependent the values received from the proximity sensor.
Follow this logic and try to code it:
1- read the flex sensor values
int val = analogRead(flexPin);
2- if it is triggered, THEN read the proximity sensor.
if(val > minimum) {
  int distance = analogRead(proximityPin); //this line depends on which proximity sensor you are using
3- play the sound accordingly to the proximity sensor (still in the if loop).
analogWrite(distance);
This logic should work fine. If you could include more info like board, flex sensor and proximity sensor, that could help.
Dat Ha
  • 2,943
  • 46
You can try using Interrupts instead of polling the sensor values, as interrupt will only be activated during rising-edge or falling edge. More info on interrupts:
Photon
  • 140
