I am checking for ways to implement multi threathing in Arduino, I have also tried using the library TimerOne but it doesn't seem to work, what I'm trying to make is an Arduino application then, every time a certain amount of time passes, it pops an item from the stack, and between these times, the application allows me to add items to the stack, both processes working in parallel of course.
The items popped and pushed are numbers.
I have already tried some other questions, but their solutions don't work, especially one that seems very useful, but for some reason doesn't work, I'm speaking about the one of the TimerOne library.
Any suggestion to fix the problem some other way would be cool.
Here is the code:
#include <TimerOne.h>
#include <QueueList.h>
#include <StackList.h>
const uint16_t NOTE_B0 = 31;
const uint16_t NOTE_C1 = 33;
const uint16_t NOTE_CS1 = 35;
const uint16_t NOTE_D1 = 37;
const uint16_t NOTE_DS1 = 39;
const uint16_t NOTE_E1 = 41;
const uint16_t NOTE_F1 = 44;
const uint16_t NOTE_FS1 = 46;
const uint16_t NOTE_G1 = 49;
. . . ETC . . .
const uint16_t NOTE_DS8 = 4978;
uint16_t Notas[] =
NOTE_B0
, NOTE_C1
. . . ETC . . .
, NOTE_C8
, NOTE_CS8
, NOTE_D8
, NOTE_DS8
QueueList<int> KeyNotesNode = QueueList<int>();
StackList<int> StackNote = StackList<int>();
char receivedChar1 = '<';
char receivedChar2 = '<';
char receivedChar[] = {receivedChar1, receivedChar2};
int TempInt = 0;
bool newData = false;
bool itPopUp = false;
int modality = 0;
Serial.begin(9600);
if(modality == 0){
Serial.println("Ingrese el tipo de funcionalidad deseada");
Serial.println("1.- Constructor de canciones en tonos");
Serial.println("2.- Juego de imposicion musical");
Timer1.initialize(150000);
Timer1.attachInterrupt( setForPop );
//Checa y controla la recepcion de los char a traves de la consola de arduino
if (Serial.available())
receiveChar();
showReceivedChar();
// . . . Here is some code to process the reception of data from serialData . . .
// From somewhere here start the loop
// . . . LOOPED . . .
//Here is used the data
if(modality == 1){
//This option doesn't matter
else if(modality == 2){
StackNote.push( (((int)(receivedChar[0]-'0'))*10)+((int)receivedChar[1]-'0') );
Serial.println("Agregado receivedChar exitosamente a la Pila");
Serial.print("Tamano Total Lista: ");
Serial.println(StackNote.count());
Serial.print("Dato:");
Serial.println( (((int)(receivedChar[0]-'0'))*10)+((int)receivedChar[1]-'0') );
Serial.print("Dato(get):");
receivedChar[0] = '<';
receivedChar[1] = '<';
//Run and show the data on the stack
if(modality == 1)
if(itPopUp){ //With this variable i want to control when it is show, this code is inside loop()
Serial.print("Reproducido con exito la nota: "); //se escribe 'éxito' pero la consola no acepta tildes, que se arrepienta :P
TempInt = StackNote.pop();
Serial.println(TempInt);
tone(9,Notas[((int)TempInt)],500);
delay(500);
} //Here the loop() end
//This function i want to run it asyncronously
void setForPop(){
if(itPopUp){
itPopUp = !itPopUp;
else{
itPopUp = !itPopUp;
