I'm in the process of trying to create a "Aurora Glow" effect using a Particle Photon and a Neopixel ring.
I have the code fully working using a single Breadboard-friendly NeoPixel however when upgrading this to a NeoPixel Ring (16 LED) the code does not run as expected
The current working code for a single NeoPixel can be found here: http://pastebin.com/Yj1cywpx
It was my assumption that i could change Line 33 from one LED to Sixteen e.g.:
FastLED.addLeds<NEOPIXEL, 6>(&led, 1);
to
FastLED.addLeds<NEOPIXEL, 6>(&led, 16);
However when I run this code rather than all NeoPixels cycling through the Aurora Colours, only the very Top LED does and rest are either off or a static colour (e.g. https://i.sstatic.net/6rY38.jpg)
Could someone please advise what i missing? Apologies if this is a "Noob" question but this is my 2nd Arduino project and I cannot understand why this would not work.
Thanks
4dogsofwar
Never used neoPixels in arduino before so this is a complete guess based on reading the code but it looks like you are only setting the colour of the first LED.
Try creating 16 LED colours:
CRGB led[16];
and then setting them all:
for (int i = 0;i<15; i++) {
  int colourIndex = index + i;
  if (colourIndex > 15)
    colourIndex -= 15;
  led[i] = ColorFromPalette(auroraPalette, colourIndex , 255, LINEARBLEND);
edit - as @rDg indicates in his answer
becomes
FastLED.addLeds<NEOPIXEL, 6>(led, 16);
since led is now an array not a single value
Finally I think paletteSize should only be 16 not 5*16, you only have 16 colours in there.
Andrew
  • 1,060
In addition to the above, you need to tweak your addLeds line:
rDg
  • 166
