My setup is as follows:
  • Arduino IDE 1.6.11
  • Arduino Pro Mini as ISP
  • ATTiny85 1602A LCD with I2C board
The libraries I use are:
The Sketch I use to test with:
#include <TinyWireM.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x3F,16,2);  // set address & 16 chars / 2 lines
void setup()
  TinyWireM.begin();                    // initialize I2C lib
  lcd.init();                           // initialize the lcd
  lcd.backlight();
  lcd.clear();  // Print a message to the LCD.
void loop()
  lcd.setCursor(0, 0);
  lcd.print("Hello World on Attiny85");
  delay(2000);
The address is 0x3F, I found this using the scanner sketch, I also tested the LCD using the Arduino Pro Mini directly, it works fine.
The result of this setup is a single line of black blocks. My guess is that the initialization failed in some way. I have tried some things to make it work:
  • Pull-ups on SDA and SCL
  • Isolated from Arduino with regulated power supply
  • Setting contract with the pot meter on the back
  • reinstall of PC
  • reinstall of Arduino IDE
  • 1MHz, 8Mhz, TinyCore default and High-Low Tech
  • Replaced FTDI
  • Replaced Tiny85
  • Replaced LCD
  • Replaced Arduino Pro Mini
Some pictures:
back of the display
the blocks
connections
[EDIT]
Final sketch:
#include <TinyWireM.h>                  // I2C Master lib for ATTinys which use USI
// #include <LiquidCrystal_I2C.h>
#include "LiquidCrystal_attiny.h"
LiquidCrystal_I2C lcd(0x27,16,2);
  // Now set up the LCD
  //lcd.begin(16,2);               // initialize the lcd
  pinMode(4, OUTPUT);
  lcd.init();
  lcd.backlight();
  lcd.home ();                   // go home
  lcd.print("Weatherstation");
  lcd.setCursor ( 0, 1 ); // go to position
  lcd.print("BMP180");
  delay(2000);
  digitalWrite(4, HIGH);
  delay(100);
  digitalWrite(4, LOW);
  delay(100);
Thijs
  • 432
After hours of Googling, I found a blog post by Dimitris Platis where he describes using an ATTiny85 with I2C LCD. I emailed the guy and he replied with a link to his LCD I2C ATTiny library on GitHub. Using this library with the TinyWireM and the right core, it instantly worked.
My final setup is with a 4.7K resistor on SDA and SCL, I will add the final sketch in the original post under [EDIT]. This adventure took me two weeks so I hope it helps someone else some day.
LCD library used: https://github.com/platisd/ATtiny85-LCD-library
TinyWireM used: https://github.com/adafruit/TinyWireM
Core used: https://github.com/vprimachenko/ArduinoTiny
Thijs
  • 432
It doesn't look like you have an Arduino Pro Mini. I2C lines on a Pro Mini are on pins A4 for SDA and A5 for SCL and those 2 pins are placed at an odd location - check picture.
Hope I was helpful :)
Arduino Pro Mini pinout
I've spent an hour doing this problem and searched a lot. If you still didn't find the solution by doing this. Pls try to reduce the clock speed from Internal 8 MHz to Internal 1MHz. That way it works mine.
Player1
  • 103
