As most of the people have posted, the values for the pipe are arbitrary, but must follow the rules per the API:
Pipes 1-5 should share the first 32 bits. Only the least significant
byte should be unique, e.g.
Before I answer your question, I think an explanation on Hex and Decimal values are needed.
The 40 bit hexadecimal is a number representation of base 16. A decimal is of base 10. So you can convert a Hex Value to Decimal. As this is out of scope for the question, you can google on how to convert from one to another. There are some online converters:
Hex to Decimal Converter
You will see when you convert the Hex value to decimal, that its just a number representation. When you convert, you drop the 0x and LL. As stated the 0x indicates the value is a hex value and LL means type Long Long.
So to answer your question, use the a converter to find a hex number like:
F0F0F0F0A1
F0F0F0F0A2
F0F0F0F0B4
F0F0F0F0E9
Just change the last 2 digits (least significant bit):
Pipes 1-5 should share the first 32 bits. Only the least significant byte should be unique, e.g.
openReadingPipe(1,0xF0F0F0F0AA);
openReadingPipe(2,0xF0F0F0F066);
Add the 0x and LL
0xF0F0F0F0A1LL
0xF0F0F0F0A2LL
0xF0F0F0F0B4LL
0xF0F0F0F0E9LL
All should work.
I am no expert on hex, as I am learning, so if I am incorrect, then please someone correct me.
Finally, the nRF24L01 datasheet makes the following point that the choice of address is not completely arbitrary:
Note: Addresses where the level shifts only one time (that is, 000FFFFFFF) can often be detected in noise and can give a false detection, which may give a raised Packet Error Rate. Addresses as a continuation of the preamble (hi-low toggling) also raises the Packet Error Rate.
