"#define" is a preprocessor directive. It defines a lable and a value, that will be positioned in the preprocessed-source-code at the same place of each occurence of the label. No type is defined, so it is a basic and dumb substitution of strings before compilation. It can then lead to errors or misunderstandings during compilation.
"const int xxx" defines a type, and locks the value of that instance. It's safer to use this method. The compiler can check for type errors and throw messages (or break compilation) if you made a mistake.
Example:
#define A 5
int dummy_integer = A
... will be preprocessed as...
int dummy_integer = 5
... and the compiler will read this statement.
However, if I remember good, you can always overwrite a preprocessor directive as follows:
#define A 5
//some code here
#undef A
#define A "my_string"
std::cout << A
That's not good. By using the "const" modifier, instead, you can't change the value (nor the type) of a variable (and so it's defined "constant").
