I'm doing a project for university and I am struggling to code and set up a rotary encoder that can control hot-cold variations. Much like the idea of communicating temperature selected by turning a dial. I would either like to control a single strip of RGB LEDs or a single bulb (changing and fading between colours at the same time).
I would like to have the dial turn from 0 - 180 degrees and relate to intense blue changing to intense red and all the colours in between as increments.
I have an Arduino Uno.
Thank you!
dda
  • 1,595
Kate
Well as I understand you want to use a rotary encoder ? Rotary encoder can turn freely. Which you can read via arduino easily with a library. You can count a number(let's say x) from 0 up to 255, and write that number to one of the color. For the other color write 255-x so when blue is fading down the red is increasing. But I suggest you to use a potentiometer which has a limited turn (about 270 degrees). Connect it to arduino's one of the analog read pins. It will give you a 10 bit value which is between 0-1023 . You can scale this down to 0-255 range with map function. [Example: "x = map(x,0,1023,0,255);" ] after that just follow the same process as before.
http://playground.arduino.cc/Main/RotaryEncoders is where the rotarty encoder libraries are. From there you can use PWM on the outputs as said. There are also some addressable RGB strips/modules that incorporate a driver IC such as adafruit neopixels where you can just write values for colour and brightness to the IC fairly simply, depending on your level of electronics knowledge.
D-on
  • 156
