I guess its a dumb question but couldnt find anything about it online. I know its possible to supply the AREF pin with 3.3 V to increase the ADC resolution.
For the project i am working on the analog voltage i will be reading will be between 0 and 2.2 and the increased resolution is a must.
I know i can use another board that has a 12 bit resolution but i really would like to make do with Uno. So i wonder if i can set an analog pin to output 2.3 V and feed it to the Aref pin.
If thats not possible please let me know why, so i can increase my knowledge
With an input voltage between 0 and 2.2 V, you can use a 2:1 voltage divider to cut the voltage in half. In your code, use analogReference(INTERNAL) to set the analog reference voltage to 1.1 V. The 1.1 V internal reference voltage is created by a bandgap circuit so is reasonably accurate.
To make the voltage divider, put two equal resistors (eg 10KΩ each) in series; connect one end of the series to your input voltage, the other end to ground, and the mid-point to an analog input pin.
James Waldby - jwpat7
  • 8,920
  • 33
The output voltage of the "analog outputs" (which are actually PWM) are dependent on supply voltage and so are not a good choice where precision is required. Consider using either an integrated voltage reference (e.g. TL431) or a constant-current source feeding a zener diode instead.
Ignacio Vazquez-Abrams
  • 17,733
  • 28
