I have an arduino where I looking for an input event then do something. Unfortunately this input event can occur like 200 times and I only care about the first notification. Since I have a DS1302 timer handy in the circuit already for other purposes I was thinking using the minutes reading out of this to squelch this event.
Here is the code I come up with:
if (digitalRead(sensor_event)==HIGH)
      if (RTC.read(tm)) {
              if(time_set)
                       if (tm.Minute > time_pushed+5)
                           time_set=0; // Unlock
               else
                        if (tm.Minute >= 55)
                          time_pushed=0;
                        else
                          time_pushed=tm.Minute; // Set global volatile min value
                        print("Sensor event");
                        time_set=1;
About the seconds and hours I don't care all I need is if this event is detected then go ahead with a function and put it on a 5 minutes hold before checking it again.
The small issue here is the minute overflow. For example if the minute is just at 56 when this happens the time_pushed would be set to 56 then the time_pushed+5 would give 61 (which of course is never reached).
Is there a better way to code this? What is the name of this time issue I having to ignore an event until x minutes? What I found for this was mostly debounce but I'm sure this has to be handled by others sometimes too.
Thanks
5 Answers5
Use the millis() function instead if you can accomodate a rollover after 50 days.
  • Take a reading of millis() at the start time.
  • time_pushed = millis() + 5 * 60 * 1000; // 5 minutes into future.
The rest of your code shouldn't require too much editing.
Transistor
  • 629
Calculate target time, rollover if necessary and check if time is already passed that point. As long as you are checking the time multiple times per minute you shouldn't run into any issues.
  if (RTC.read(tm)) {
          if(time_set)
                   if (tm.Minute >= targettime)
           else
                    targettime=tm.Minute+5; // Set global volatile min value
                    targettime=targettime % 60;
                    time_set=1;
Cem Kalyoncu
  • 121
The proper way to do that depends on whether the event is guaranteed to happen at least once every 49.7 days. If this is the case then, as Tom Carpenter suggested in a comment, you can just test for now - last_event >= hold_time:
void loop()
    uint32_t now = millis();
    static uint32_t last_event = -hold_time;
    // Detect the event if it did not happen in the last five minutes.
    if (now - last_event >= hold_time
            && digitalRead(sensor_event) == HIGH) {
        Serial.println("Sensor event");
        last_event = now;
If you can have 49.7 days without a single event, then this approach fails because last_event is ambiguous. The simplest solution is probably to implement a state machine with only two states, as the event detection is either “on hold” or it is not:
void loop()
    static bool on_hold;
    static uint32_t last_event;
    // Remove the hold after five minutes.
    if (on_hold && now - last_event >= hold_time) {
        on_hold = false;
    // Detect the event.
    if (!on_hold && digitalRead(sensor_event) == HIGH) {
        on_hold = true;
        last_event = now;
Now I would want to insist on a specific point: in either approach the millis() rollover is not an issue. The choice between the first and the second approach depends solely on the maximum time between the events, not on how long the program is meant to run.
Edgar Bonet
  • 45,094
  • 81
Just to save a lot of headaches for everybody who wonders here and still have a problem with this code:
uint32_t hold_time = 1*60*1000; // 1 minute will never work
uint32_t hold_time = 60000; // 1 minute will work
You must define the value as an EXACT number, not putting in multiplication and rely on the compiler to calculate it for you.
Probably because it's unsigned long and screws up something with the multiplication but with the first example you will be put on hold for days, maybe forever.
Don't bother with the RTC, just use millis(). Or just convert the time in hours/minutes/seconds to a single number in seconds (i.e. UNIX timestamp) and use that. Then use these time comparison macros:
#define time_after(unknown, known) ((long)(known) - (long)(unknown) < 0)
#define time_before(unknown, known) ((long)(unknown) - (long)(known) < 0)
#define time_after_eq(unknown, known) ((long)(unknown) - (long)(known) >= 0)
#define time_before_eq(unknown, known) ((long)(known) - (long)(unknown) >= 0)
Then do something like this in your main loop, with a variable unsigned long sample_timer that's initialized to 0 at the start of your program:
if (time_after_eq(millis(), sample_timer))
    if (event)
        sample_timer = millis() + 5*60*1000;
        // handle event...
These time comparison macros will properly handle overflow if you use unsigned long for your timestamps.
alex.forencich
  • 262
