I hate to start with "I hate delays", but I hate delays :)
Why have you included them? If you want your outputs to be slower, increase your intervals.
Use a state machine instead:
unsigned long previousMillis = 0;
unsigned long currentMillis = 0;
unsigned long interval1 = 300;
unsigned long interval2 = 350;
#define LEDPIN 13
int state = 0;
// 0 = waiting for sensor one interval
// 1 = another 50ms for sensor two
currentMillis=millis();
previousMillis=currentMillis;
Serial.begin(9600);
pinMode(LEDPIN, OUTPUT);
digitalWrite(A0, HIGH); // internal pullups
digitalWrite(A1, HIGH); // internal pullups
currentMillis = millis();
if ( state == 0 )
if ( currentMillis - previousMillis >= interval1)
int val1 = analogRead(0);
Serial.print( currentMillis );
Serial.print(" Sensor Value 1 is ");
Serial.println(val1);
digitalWrite(LEDPIN, HIGH);
state = 1;
else
if ( currentMillis - previousMillis >= interval2)
int val2 = analogRead(1);
Serial.print(" Sensor Value 2 is ");
Serial.println(val2);
digitalWrite(LEDPIN, LOW);
state = 0;
previousMillis = currentMillis;
This way, test 2 will only be conducted 50ms after test 1 and then previous millis is reset
edit: I fixed the interval test regarding overflow (which you had correctly in the first place)
edit2: (I'm having too much fun with this)
assuming you want each test conducted at specifically the interval requested (ie sensor 1 every 300ms and sensor 2 every 350ms), I have come up with v2 (and removed the state machine, since it's just not needed)
unsigned long previous1 = 0;
unsigned long previous2 = 0;
const int LEDPIN = 13;
previous1=currentMillis;
previous2=currentMillis;
Serial.begin(9600);
if ( currentMillis - previous1 >= interval1)
previous1 = currentMillis;
Serial.print(currentMillis);
if ( currentMillis - previous2 >= interval2)
previous2 = currentMillis;
edit: including some sample output to indicate a working state:
188609 Sensor Value 1 is 15
188659 Sensor Value 2 is 14
188959 Sensor Value 1 is 14
189009 Sensor Value 2 is 15
189309 Sensor Value 1 is 15
189359 Sensor Value 2 is 14
189659 Sensor Value 1 is 14
189709 Sensor Value 2 is 1017
190009 Sensor Value 1 is 15
190059 Sensor Value 2 is 1002
190359 Sensor Value 1 is 14
190409 Sensor Value 2 is 1013
190709 Sensor Value 1 is 14
190759 Sensor Value 2 is 1019
191059 Sensor Value 1 is 15
191109 Sensor Value 2 is 1004
191409 Sensor Value 1 is 14
191459 Sensor Value 2 is 1019
191759 Sensor Value 1 is 15
191809 Sensor Value 2 is 15
192109 Sensor Value 1 is 14
192159 Sensor Value 2 is 15
192459 Sensor Value 1 is 14
192509 Sensor Value 2 is 14
192809 Sensor Value 1 is 15
192859 Sensor Value 2 is 15
193159 Sensor Value 1 is 14
193209 Sensor Value 2 is 16
193509 Sensor Value 1 is 14
193559 Sensor Value 2 is 15
193859 Sensor Value 1 is 1005
193909 Sensor Value 2 is 1021
194209 Sensor Value 1 is 1021
194259 Sensor Value 2 is 1003
194560 Sensor Value 1 is 1004
194609 Sensor Value 2 is 1020
194909 Sensor Value 1 is 1020
194959 Sensor Value 2 is 1004
195259 Sensor Value 1 is 15
195309 Sensor Value 2 is 1001
195609 Sensor Value 1 is 14
195659 Sensor Value 2 is 1022
195959 Sensor Value 1 is 15
196009 Sensor Value 2 is 998
196310 Sensor Value 1 is 15
196359 Sensor Value 2 is 1019
196659 Sensor Value 1 is 15
196709 Sensor Value 2 is 1002
197009 Sensor Value 1 is 14
197059 Sensor Value 2 is 15
197359 Sensor Value 1 is 14
197409 Sensor Value 2 is 15
197709 Sensor Value 1 is 15
197760 Sensor Value 2 is 13
198060 Sensor Value 1 is 14
198110 Sensor Value 2 is 15
198410 Sensor Value 1 is 15
198460 Sensor Value 2 is 14
