23
I need to know how I can write integer values in EEPROM and retain the value on power on.
char *Red = strstr(myTestUrl, "/R");
if (Red) {
  int RedValue  = atoi(Red + 2);
  analogWrite(12, RedValue);
  Serial.println("Red :");
  Serial.println(RedValue);
I want to write RedValue in EEPROM. How can it be done?
gre_gor
  • 1,682
  • 28
MICRO
  • 500
5 Answers5
38
While EEPROM.read and EEPROM.write are valid methods, it's like mopping the floor with a toothbrush. Use EEPROM.put and EEPROM.get instead.
For example:
#include <EEPROM.h>
void setup()
  Serial.begin(9600);
  uint addr = 0;
  // fake data
  struct {
    uint val = 0;
    char str[20] = "";
  } data;
  // commit 512 bytes of ESP8266 flash (for "EEPROM" emulation)
  // this step actually loads the content (512 bytes) of flash into
  // a 512-byte-array cache in RAM
  EEPROM.begin(512);
  // read bytes (i.e. sizeof(data) from "EEPROM"),
  // in reality, reads from byte-array cache
  // cast bytes into structure called data
  EEPROM.get(addr,data);
  Serial.println("Old values are: "+String(data.val)+","+String(data.str));
  // fiddle with the data "read" from EEPROM
  data.val += 5;
  if ( strcmp(data.str,"hello") == 0 )
      strncpy(data.str, "jerry",20);
  else
      strncpy(data.str, "hello",20);
  // replace values in byte-array cache with modified data
  // no changes made to flash, all in local byte-array cache
  EEPROM.put(addr,data);
  // actually write the content of byte-array cache to
  // hardware flash.  flash write occurs if and only if one or more byte
  // in byte-array cache has been changed, but if so, ALL 512 bytes are
  // written to flash
  EEPROM.commit();
  // clear 'data' structure
  data.val = 0;
  strncpy(data.str,"",20);
  // reload data for EEPROM, see the change
  //   OOPS, not actually reading flash, but reading byte-array cache (in RAM),
  //   power cycle ESP8266 to really see the flash/"EEPROM" updated
  Serial.println("New values are: "+String(data.val)+","+String(data.str));
void loop()
  delay(1000);
UPDATE: If you want to understand how the "EEPROM" is emulated in the ESP8266, you might want to reference https://github.com/esp8266/Arduino/tree/master/libraries/EEPROM, specifically, EEPROM.h.
Also, EEPROM.end is not needed, it simply clears the local byte-array cache of the flash/EEPROM from RAM. It serves on other function.
codechimp
  • 496
EEPROM.write(pos, val) writes one byte (val) at the address giving by pos. An "int" in ESP8266 takes 4 bytes, so it's a little more complicated, because EEPROM works in bytes, not ints.
Here is a code for writing one int val at some position pos in the EEPROM:
void eeWriteInt(int pos, int val) {
    byte* p = (byte*) &val;
    EEPROM.write(pos, *p);
    EEPROM.write(pos + 1, *(p + 1));
    EEPROM.write(pos + 2, *(p + 2));
    EEPROM.write(pos + 3, *(p + 3));
    EEPROM.commit();
and, of course, you need to read it back:
int eeGetInt(int pos) {
  int val;
  *p        = EEPROM.read(pos);
  *(p + 1)  = EEPROM.read(pos + 1);
  *(p + 2)  = EEPROM.read(pos + 2);
  *(p + 3)  = EEPROM.read(pos + 3);
  return val;
In Arduino you call EEPROM.begin(), but in ESP8266 you have to call EEPROM.begin(n), where n is the total number of bytes you will need.
And remember that EEPROM have a short life span (by number of writes). You must minimize the number of writes!
EEPROM is permanent; you don't need to do nothing.
gre_gor
  • 1,682
  • 28
Method using the number of letters.
#include <ESP8266WiFi.h>
const char* SSID = "R360"; //MAX 32
const char* PASSWORD = "HFDYUK64323246"; //MAX 32
#include <EEPROM.h>
  Serial.begin(9600);
  EEPROM_ESP8266_GRABAR(SSID, 0); //Primero de 0 al 32, del 32 al 64, etc
  EEPROM_ESP8266_GRABAR(PASSWORD, 32); //SAVE
  Serial.println();
  Serial.println(EEPROM_ESP8266_LEER(0, 32));//Primero de 0 al 32, del 32 al 64, etc
  Serial.println(EEPROM_ESP8266_LEER(32, 64));
  WiFi.begin(EEPROM_ESP8266_LEER(0,32).c_str(), EEPROM_ESP8266_LEER(32,64).c_str());
void loop() {}
void EEPROM_ESP8266_GRABAR(String buffer, int N) {
  EEPROM.begin(512); delay(10);
  for (int L = 0; L < 32; ++L) {
    EEPROM.write(N + L, buffer[L]);
  EEPROM.commit();
String EEPROM_ESP8266_LEER(int min, int max) {
  EEPROM.begin(512); delay(10); String buffer;
  for (int L = min; L < max; ++L)
    if (isAlphaNumeric(EEPROM.read(L)))
      buffer += char(EEPROM.read(L));
  return buffer;
gre_gor
  • 1,682
  • 28
360
  • 41
Use #include <EEPROM.h>
EEPROM.begin(size); //Size can be anywhere between 4 and 4096 bytes.
EEPROM.write(0, RedValue);   // To store in 0th Location
EEPROM.commit();
MICRO
  • 500
I use 2 separate functions in my code on ESP8266 - one with EEPROM.put(), one with EEPROM.get().
I had EEPROM.begin(sizeof...); only in EEPROM.put() function and put worked. But it took me quite a while, until I found out, that it must be used before EEPROM.get() as well.
gre_gor
  • 1,682
  • 28
PeterM
