I'm trying to debug a problem and need to reduce the speed of the clock on my Arduino Mega from 16MHz to 8MHz.
I can't find any simple way of doing so, so I wanted to know if there were any gurus here who knew if this was possible, as well as how to do it.
WITHOUT PRESCALER:
long int runTime;
void setup()
  Serial.begin(9600);     //Setting the data transfer rate
void loop()
  delay(1000);
  runTime = millis();
  Serial.print("Runetime: ");
  Serial.println(runTime);
  delay(100);
  exit(0);
OUTPUT: 999
WITH PRESCALER:
long int runTime;
void setup()
  Serial.begin(19200);   //Setting the data transfer rate for when CLK Freq. is Halfed
  CLKPR = _BV(CLKPCE);  // enable change of the clock prescaler
  CLKPR = _BV(CLKPS0);  // divide frequency by 2
void loop()
  delay(1000);
  runTime = millis();
  delay(100);
  exit(0);
OUTPUT: 999
Isabel Alphonse
  • 203
You can set the clock prescaler for that:
    noInterrupts();
    interrupts();
This is explained in section 10.12 and 10.13 of the ATmega2560 datasheet.
Of course, changing the clock frequency will mess with the time-related function (millis(), delay() and co.) and the baud rate of the serial port.
Edit: Here is a small program to demonstrate the slowing of the clock:
//#define SLOW_CLOCK
void setup()
#ifdef SLOW_CLOCK
    noInterrupts();
    interrupts();
#endif
    pinMode(LED_BUILTIN, OUTPUT);
void loop()
    digitalWrite(LED_BUILTIN, HIGH);
    delay(500);
    digitalWrite(LED_BUILTIN, LOW);
    delay(500);
This makes the LED flash at 1 Hz. If you uncomment the line #define SLOW_CLOCK, it instead flashes at 0.5 Hz.
Edgar Bonet
  • 45,094
  • 81
