I'm trying to have a millis() timer run to emulate a hardware timer inside a library, but I'm having issues compiling the code. I want the callback (pseudo ISR) to be part of the class, and not use global variables.
I'm using Christensen's / Monk's Timer library, but I'm open to suggestions if there are other better/easier timer libraries out there.
This is what I have so far. It's just an example for me to understand how this might work. I'm sure there are better ways of making an LED blink, but this is just for illustrative purposes.
Compiling gives a bunch of "invalid use of member variables in static functions" errors.
error: invalid use of member 'Blink::_led_status' in static member function int _led_status;
EDIT
After trying to add glue routines as per your other answer I can seem to get one instance working, but adding another stops the first light from blinking, and the second one blinks on and off at the wrong times.
The test library is on github
Blink.h
#ifndef Blink_h
#define Blink_h
#include "Arduino.h"
#include <Timer.h> // https://github.com/JChristensen/Timer/master
    // Timer.h uses millis() instead of built in timers
class Blink {
public:
  Blink (int led_pin, int duration);
  void begin ();
  void updateTimer();
private:
  static void _callbackGlue();
  void _callback();
  static Blink *_instance;
  Timer *_blink_timer;
  int _led_pin;
  int _duration;
  int _led_status;
  int _blink_event;
#endif
blink.cpp
#include "Blink.h"
Blink *Blink::_instance;
Blink::Blink (int led_pin, int duration) {
  _blink_timer = new Timer();
  _led_status = 0;
  _led_pin = led_pin;
  _duration = duration;
  pinMode(_led_pin, OUTPUT);
  digitalWrite(_led_pin, LOW);
void Blink::begin () {
  _blink_event = _blink_timer->every(_duration, _callbackGlue);
  _instance = this;
void Blink::_callbackGlue() {
  _instance->_callback();
void Blink::_callback() {
  if (_led_status == 0) {
    digitalWrite(_led_pin, HIGH);
    _led_status = 1;
  } else if (_led_status == 1) {
    _led_status = 0;
void Blink::updateTimer() {
  _blink_timer->update();
test/test.ino
#include "Blink.h"
Blink first_blink (13, 500);
//Blink second_blink (12, 1000);
  Serial.begin(9600);
  Serial.println("Starting...");
  first_blink.begin();
  //second_blink.begin();
  first_blink.updateTimer();
  //second_blink.updateTimer();
dda
  • 1,595
waspinator
Nick Gammon's answer is good for one Timer - but now you want two!
OK, then you can take advantage of the Timer Library's context parameter. What's that? If you take a look at the header for every(), you'll see as well as passing in the function to call, you can also pass in another value (called context) to pass back to that function when it fires*. So instead of you remembering just one copy of instance, get each Timer to remember it for you.
*If you can't see the context parameter in Timer.h, then make sure you're using the v2.1 branch, not master.
So:
  1. Get rid of _instance everywhere.
  2. Change:
    to
    static void _callbackGlue(void *context);
  3. Change:
    to
    void Blink::_callbackGlue(void *context)
    ((Blink *)context)->_callback();
  4. Change:
    to
    _blink_event = _blink_timer->every(_duration, _callbackGlue, this);
Note that I've submitted these changes as a Pull Request on your GitHub repo.
Incidentally:
You don't need _blink_timer to be a pointer. Get rid of the *, get rid of the line with new Timer() in it, and replace all your _blink_timer-> with _blink_timer.
John Burger
  • 1,885
You may add handler (AKA hook) functions using function pointer to the Timer0 ISR inside the core wiring.c source file shipped with Arduino core, and assign latter (attache) this function pointer to any desired function in the other library/class or in the main application code.
More about this trick in this article here.
Yahya Tawil
  • 141
