I've got an array of char* with serial data that I'm trying to remove ':' from. I have tried to iterate through the char*, find and remove any colons but it just comes out as garbage.
  char* espData[15];
  // pull data from serial and tokenize with strtok > feed to espData
  for(int x = 0; x < index-1; x++){
    size_t nullTerm = strlen(espData[x]);
    espData[x][nullTerm - 1] = '\0';
    char* output
    for(size_t i = 0; i < strlen(espData[x]); ++i){
      if(espData[x][i] != ':') output += espData[x][i];
    espData[x] = output;
    Serial.println(espData[x]);
Moving the null character works fine (I wanted to get rid of the last character in every string). Most of the answers I found for general C++ used std::string which we don't have access to.
user3704293
  • 471
Tri42
You've assumed that a char * is some kind of string object, since you've got the following line of code: output += espData[x][i];, and then later espData[x] = output;
It quite simply doesn't work like that. At best you can point output inside espData[x] and then do some other logic: but your attempt to "accumulate" the correct characters is incorrect.
Please consider the following code instead:
char* espData[15];
    size_t nullTerm = strlen(espData[x]); // Get current length
    char* output = espData[x];            // Start of string
    for (size_t i = 0; i < nullTerm; ++i){
        if(espData[x][i] != ':') {        // If it's NOT a colon
            *output++ = espData[x][i];    // Copy character 'up'
        } // if
                                          // If it WAS a colon, then
                                          // output does NOT get incremented
    } // for
    *output = '\0'; // End string off with NUL
} // for
John Burger
  • 1,885
