I'm using the RGBLCDShield library and a few analog input signals and since it seems the interrupts are being used by the SPI interface of the LCD Shield, I decided to try it with FreeRTOS instead. I don't currently have my arduino with me (left if at parents') but I wanted to get some feedback on this code to see if it would run properly; I might not be getting my UNO back for a few days but I wanted to at least have a usable code ready to be tested when I do get it.
The Analog inputs are just 2 low level signals and the digital outputs just control some IC switches. One PWM is fed through a lowpass filter and into an amplifier input.
Here is my code in it's entirety:
#include <Arduino_FreeRTOS.h>
#include <Adafruit_RGBLCDShield.h>
#include <Wire.h>
#include <math.h>
// define tasks
void TaskAnalogRead( void *pvParameters ); // Check voltage input
void TaskLCDShield( void *pvParameters ); // Control Display
void TaskUserInput( void *pvParameters ); // User Interface - System Process
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
unsigned int vSet = 0; // Desired Voltage (potentiometer set)
unsigned int vOut = 0; // Voltage on capacitor
// the setup function runs once when you press reset or power the board
// Set up Tasks to run independently
xTaskCreate(
TaskAnalogRead
, (const portCHAR *) "AnalogRead" // A name just for humans
, 128 // This stack size can be checked & adjusted by reading the Stack Highwater
, NULL
, 2 // Priority, with 1 being the highest, and 4 being the lowest.
, NULL );
xTaskCreate(
TaskLCDShield
, (const portCHAR *) "LCDShield"
, 128 // Stack size
, NULL
, 3 // Priority
, NULL );
xTaskCreate(
TaskUserInput
, (const portCHAR *) "UserInput"
, 128
, NULL
, 1
, NULL );
// Now the task scheduler, which takes over control of scheduling individual tasks, is automatically started.
lcd.begin(16, 2);
void loop()
// Empty. Things are done in Tasks.
/*---------------------- Tasks ---------------------*/
void TaskLCDShield(void *pvParameters) // This is a task.
(void) pvParameters;
// Start Display
lcd.setBacklight(0x7);
lcd.setCursor(0,0);
lcd.println(" PORTABLE SPARK ");
delay(5000);
lcd.clear();
for (;;) // Continuously Update display
int volts = vSet * 100.0;
int chg = (vOut * 0.488)/volts;
int vpos, cpos;
lcd.setCursor(0,0);
lcd.print("Voltage: ");
lcd.setCursor(15, 0);
lcd.print("V");
lcd.setCursor(0,1);
lcd.print("Charge : ");
lcd.setCursor(15,1);
lcd.print("%");
lcd.setCursor(9,0);
if(volts < 100)
lcd.print(" ");
vpos = 13;
else if(volts < 1000)
lcd.print(" ");
vpos = 11;
else if(volts < 10000)
lcd.print(" ");
vpos = 10;
else vpos = 9;
lcd.setCursor(vpos,0);
lcd.print(volts, DEC);
lcd.setCursor(9,1);
if(chg < 10)
lcd.print(" ");
cpos = 13;
else if(chg < 100)
lcd.print(" ");
cpos = 12;
else cpos = 11;
lcd.setCursor(cpos,1);
lcd.print(chg, DEC);
//digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
vTaskDelay( 1000 / portTICK_PERIOD_MS ); // wait for one second
//digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
//vTaskDelay( 1000 / portTICK_PERIOD_MS ); // wait for one second
void TaskAnalogRead(void *pvParameters) // Read Analog Voltages (VSet, Emonitor)
for (;;)
int eMon = analogRead(A0); // read input pins
vTaskDelay(1);
int vA = analogRead(A1);
vSet = (vA/1024) * 15000; // calculate actual values
vOut = (5.0/1024.0) * 10000 * eMon;
vTaskDelay(10); // one tick delay (300ms) in between reads
} // End Analog Read
void TaskUserInput(void *pvParameters) // User Interface
// initialize digital pin 13 as an output.
pinMode(8, OUTPUT); // Fire signal
pinMode(7, OUTPUT); // Charge/Discharge signal
pinMode(5, OUTPUT); // Eprgm PWM output
pinMode(4, OUTPUT); // Cam/DAQ trigger
bool charge = false; // charge flag
for (;;)
uint8_t button = lcd.readButtons();
switch(charge)
case true:
analogWrite(5, (vSet * 0.0204)/5);
vTaskDelay(1);
digitalWrite(7, HIGH);
vTaskDelay(1);
break;
default:
analogWrite(5, 0);
vTaskDelay(1);
digitalWrite(7, LOW);
vTaskDelay(1);
break;
} // End Switch(charge)
if(button & BUTTON_UP) // Charge/Discharge button
charge = !charge;
} // end if
else if(button & BUTTON_DOWN) // Fire!
digitalWrite(8, HIGH);
vTaskDelay(1);
digitalWrite(4, HIGH);
vTaskDelay(1);
charge = false;
vTaskDelay(1);
digitalWrite(4, LOW);
vTaskDelay(1);
digitalWrite(8, LOW);
} // End else if
} // End for
} // End User Interface
My specific concern is with the 2wire interface of the LCD shield and whether it would be able to communicate with the Arduino - especially when it needs to read the button inputs.
Also, how do I determine the stack size for each task? Is 128 for each enough to handle what I have?
