I'm using a LinkIt ONE Arduino-like to send sensor data via MQTT.
It always worked very well, then out of the blue, it stopped printing anything using Serial.print();
But if I ommit the "Serial.begin(9600);" line, the code runs normally, sending sensor data via MQTT, even if I can't see debug output.
This shows the problem is on the Serial handling.
Since I can't show the entire code here, here's two test cases:
1.
void setup(){
  Serial.begin(9600);
  Serial1.begin(9600);
  while(!Serial); //Wait until Serial is ready before printing
Serial1.println("This came from serial 1"); //does nothing Serial.println("This came from serial 0"); //works delay(1000); }
It shows me the following output:
Thi
Looks like the module freezes before the third iteration.
But if I omit the lines that aren't printed, from Serial1:
2.
void setup(){
  Serial.begin(9600);
void loop() { Serial.println("This came from serial 0"); //works delay(1000); }
No output is shown on Serial monitor.
What is the reason behind this? Since Serial1 prints nothing, why can't I remove it?
Observations:
I tested the code in two LinkIt ONE modules of the same model.
I tested it in Arduino SDK 1.6.8, 1.5.6r2 and 1.6.5.
Edit:
Just made another test using the code below. It blinked two times showing that
Serial.begin(9600); runs
while(!Serial); runs (it didn't freeze the module waiting for Serial to initialize)
But Serial.println(); freezes
void setup(){
  pinMode(13, OUTPUT);
  blink();
  Serial.begin(9600);
  blink();
Serial.println("This came from serial 0"); //works blink(); delay(1000); }
void blink(){ digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level) delay(1000); // wait for a second digitalWrite(13, LOW); // turn the LED off by making the voltage LOW delay(1000); }
Paulostation
  • 41
The problem was solved by:
  • making a clean install of Arduino IDE 1.6.9
  • uploading the LinkIt SDK on board manager from version 1.1.17 to 1.1.23.
Then the Serial function returned back to normal.
Paulostation
  • 41
I have bit similar problem. I thing, this is arduino bug. When start serial port, must be take out data from Rx. When read buffer overflow my arduino freeze. I can't run delay because when arduino wait, serial port can receive lot of data -> overflow -> freeze. Instead of delay I use own function wait(milis):
void wait(unsigned long wait_time){
  unsigned long start_time;
  start_time=millis();
  while ( millis() < (start_time+wait_time) ){
    if (serial.available() > 0) serial.read();
ondra
The problem isn't actually in Serial, it's somewhere else. Many things are able to make the Arduino hang in mid-write. Show us the any code that you have written, plus links to the libraries you are using, and you'll have your answer in short order.
I will guess that you have a low-RAM condition, perhaps exacerbated by heap usage. Do you use String? I notice you're not using the F macro to save RAM.
slash-dev
  • 2,029
