I am using an Arduino Mega board with a SIM900 GSM.
My goal is to be able to text the GSM with a value of two digits (ex: 79) and then store that value as a variable in the code. I know how to set up the Mega and the GSM in terms of wiring and initialization of ports, but how would I write a short function to test the incoming values and save them to a variable?
I thought about testing each bit individually, storing each one as a separate variable, and then adding them for the total. For example, if the GSM received "#79" as a text I stored the value 7 as an integer variable named One and the value 9 as an integer variable named Two. Then I did
Total = (One*10)+Two.
I am posting my code below that used this method, although it has not proved to be useful. If anyone has any suggestions I would greatly appreciate it.
#include <SoftwareSerial.h>   //GSM Library
int Max_temp;
float threshold;
SoftwareSerial SIM900(18, 19);
String destinationNumber = "+17186578989";
String outMessage1 = "Please enter the maximum desired room temp";
char inchar; // Will hold the incoming character from the GSM shield when user texts it
int M_one;
int M_zero;
void GSM_SEND_MAX();
void GSM_RECEIVE_MAX();
void setup()
   Serial.begin(9600);
//GSM setup:
  Serial1.begin(19200);  // wake up the GSM shield
  delay(20000); // give time to log on to network.
  Serial1.print("AT+CMGF=1\r"); // set SMS mode to text
  delay(100);
  Serial1.print("AT+CNMI=2,2,0,0,0\r"); // blurt out contents of new SMS upon receipt to the GSM shield's serial out
  delay(100);
}// end void set up()
void loop()
  GSM_SEND_MAX();
  GSM_RECEIVE_MAX();
}// end void loop ()
/////Functions
void GSM_SEND_MAX()
  Serial.println("sending text");
  delay(1000);
  Serial1.println("AT + CMGS = \"" + destinationNumber +"\"");
  delay(1000);
  Serial1.print(outMessage1);
  delay(1000);
  Serial1.write((char)26); //ctrl+z
  delay(1000);
  Serial.println("send text");
}//end GSM_SEND_MAX funtion
  //If a character comes in from the cellular module...
 while (Serial1.peek() != '#' )
    inchar=Serial1.read();
    Serial.print("bad char ");
    Serial.println(inchar);
    delay(500);
   }// end while #1
 inchar=Serial1.peek();
 Serial.println("out of loop 1");
 while (Serial1.available() != 0) //While #2 reads incoming char
    Serial.println("in loop 2");
if (inchar=='#')
  delay(10);
  Serial.print("got #");
  M_one=Serial1.read();
  if (M_one >= 0 )
  delay(10);
  Serial.println();
  Serial.print("got M_one");
  Serial.print(M_one);
  M_zero=Serial1.read();
      if (M_zero >= 0)
          Serial.println();
          Serial.print("got M_zero");
          Serial.print(M_zero);
       }//end m_zero
  }//end m_one
  Max_temp = (M_one *10) + M_zero;
  Serial.println();
  Serial.print("Max_temp=");
  Serial.print(Max_temp);
  } //end if (inchar==#)
 }// end while #2 loop
}//end GSM_RECEIVE_MAX function
Greenonline
  • 3,152
  • 36
  • 48
user131763
  • 41
